Inleiding
In order to remove the bottom cover, you will need the nylon spudger and the Phillips 1 Screwdriver Head.
Wat je nodig hebt
Flip the laptop over to expose the underside.
Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
8 andere personen hebben deze handleiding voltooid.
4 opmerkingen
what should I do if I don’t have a nylon spudger? Is it safe to use my fingers to pry it open? I know I need to be careful about static or else it could fry the comp.
Glad I read this…didn't know about the 2 screws under the grip pads. Once again the internet comes through.
But where can i purchase the bottom cover
