Inleiding
The touchpad is the component used to maneuver the cursor around the desktop and for making selections from various menus. This guide will provide detail directions for the proper removal of the touchpad.
Wat je nodig hebt
Use the plastic opening tool to remove the gray rubber pads on the bottom of the laptop. For our device we only needed to remove the two at the top.
Carefully, pull back the locking clip of the connector using a plastic opening tool and disconnect cable.
