Ga door naar hoofdinhoud
HP Envy x360 m6-aq005dx Audio Jack Replacement
Wat je nodig hebt
  1. HP Envy x360 m6-aq005dx Audio Jack Replacement, Back Panel: stap 1, afbeelding 1 van 2 HP Envy x360 m6-aq005dx Audio Jack Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Use the plastic opening tool to remove the gray rubber pads on the bottom of the laptop. For our device we only needed to remove the two at the top.
  2. HP Envy x360 m6-aq005dx Audio Jack Replacement: stap 2, afbeelding 1 van 3 HP Envy x360 m6-aq005dx Audio Jack Replacement: stap 2, afbeelding 2 van 3 HP Envy x360 m6-aq005dx Audio Jack Replacement: stap 2, afbeelding 3 van 3
    • Use a Torx T5 screwdriver to remove the six 5.1 mm screws.
    • Use a JIS #1 screwdriver to remove the two 7.2mm screws.
  3. HP Envy x360 m6-aq005dx Audio Jack Replacement: stap 3, afbeelding 1 van 1
    • Use a plastic opening tool to pry open the case. Go slowly around the edge. You will hear popping noises, such are due to popping open the small joints that keep the cover attached.
  4. HP Envy x360 m6-aq005dx Audio Jack Replacement, Audio Jack: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Battery might cause a small electric shock.
    • Use tweezers to disconnect the battery from the motherboard.
  5. HP Envy x360 m6-aq005dx Audio Jack Replacement: stap 5, afbeelding 1 van 2 HP Envy x360 m6-aq005dx Audio Jack Replacement: stap 5, afbeelding 2 van 2
    • Our pictures show the fan removed from the laptop. You do not need to remove the fan for this guide.
    • Use a PH0 bit to remove the three 4.7 mm screws.
  6. HP Envy x360 m6-aq005dx Audio Jack Replacement: stap 6, afbeelding 1 van 2 HP Envy x360 m6-aq005dx Audio Jack Replacement: stap 6, afbeelding 2 van 2
    • Use the plastic opening tool to open the security connector. then pull the ribbon cable to disconnect it from the motherboard.
Conclusie
Matthew Martin
718 Reputatie
5 handleidingen geschreven
USF Tampa, Team S13-G17, Cagle Fall 2017 Lid van USF Tampa, Team S13-G17, Cagle Fall 2017
USFT-CAGLE-F17S13G17
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 392
