Ga door naar hoofdinhoud
HP Envy x360 15m-cn0012dx Daughterboard Replacement
Wat je nodig hebt
  1. HP Envy x360 15m-cn0012dx Daughterboard Replacement, Daughterboard: stap 1, afbeelding 1 van 2 HP Envy x360 15m-cn0012dx Daughterboard Replacement, Daughterboard: stap 1, afbeelding 2 van 2
    • Make sure the computer is turned off, and remove all cables.
    • Set the laptop face down.
    • Peel back the grey screw guards, along the top and bottom edge of the back case. It may be helpful to use a spudger to get started.
    • Peel slowly to avoid tearing the rubber covers.
  2. HP Envy x360 15m-cn0012dx Daughterboard Replacement: stap 2, afbeelding 1 van 3 HP Envy x360 15m-cn0012dx Daughterboard Replacement: stap 2, afbeelding 2 van 3 HP Envy x360 15m-cn0012dx Daughterboard Replacement: stap 2, afbeelding 3 van 3
    • Using the Phillips #0 screwdriver, remove the seven 5mm screws from the back case.
  3. HP Envy x360 15m-cn0012dx Daughterboard Replacement: stap 3, afbeelding 1 van 3 HP Envy x360 15m-cn0012dx Daughterboard Replacement: stap 3, afbeelding 2 van 3 HP Envy x360 15m-cn0012dx Daughterboard Replacement: stap 3, afbeelding 3 van 3
    • Pry open the back cover using the iFixit Opening Tool.
    • While using the tool, place a pick at each corner of the computer (be careful and do it slowly).
    • Once all the corners are slightly lifted, carefully pop off the back cover.
  4. HP Envy x360 15m-cn0012dx Daughterboard Replacement: stap 4, afbeelding 1 van 3 HP Envy x360 15m-cn0012dx Daughterboard Replacement: stap 4, afbeelding 2 van 3 HP Envy x360 15m-cn0012dx Daughterboard Replacement: stap 4, afbeelding 3 van 3
    • Use the iFixit opening tool to unlatch the ZIF connector with the cable labelled 'SD' from the daughterboard.
    • Slide out the interconnect ribbon cable.
  5. HP Envy x360 15m-cn0012dx Daughterboard Replacement: stap 5, afbeelding 1 van 3 HP Envy x360 15m-cn0012dx Daughterboard Replacement: stap 5, afbeelding 2 van 3 HP Envy x360 15m-cn0012dx Daughterboard Replacement: stap 5, afbeelding 3 van 3
    • Using a Phillips #0 screwdriver, remove the two 4mm screws on holding down the SD card daughterboard.
    • Remove the SD card daughterboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Grace Daleki
487 Reputatie
3 handleidingen geschreven
UW Stout, Team S1-G3, Schneider-Bateman Spring 2020 Lid van UW Stout, Team S1-G3, Schneider-Bateman Spring 2020
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G3
3 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 34
Altijd: 826
