Ga door naar hoofdinhoud
HP Envy x360 15m-cn0012dx Fan Replacement
Wat je nodig hebt
  1. HP Envy x360 15m-cn0012dx  Fan Replacement, Fan: stap 1, afbeelding 1 van 2 HP Envy x360 15m-cn0012dx  Fan Replacement, Fan: stap 1, afbeelding 2 van 2
    • Make sure the computer is turned off, and remove all cables.
    • Set the laptop face down.
    • Peel back the grey screw guards, along the top and bottom edge of the back case. It may be helpful to use a spudger to get started.
    • Peel slowly to avoid tearing the rubber covers.
  2. HP Envy x360 15m-cn0012dx  Fan Replacement: stap 2, afbeelding 1 van 3 HP Envy x360 15m-cn0012dx  Fan Replacement: stap 2, afbeelding 2 van 3 HP Envy x360 15m-cn0012dx  Fan Replacement: stap 2, afbeelding 3 van 3
    • Using the Phillips #0 screwdriver, remove the seven 5mm screws from the back case.
  3. HP Envy x360 15m-cn0012dx  Fan Replacement: stap 3, afbeelding 1 van 3 HP Envy x360 15m-cn0012dx  Fan Replacement: stap 3, afbeelding 2 van 3 HP Envy x360 15m-cn0012dx  Fan Replacement: stap 3, afbeelding 3 van 3
    • Pry open the back cover using the iFixit Opening Tool.
    • While using the tool, place a pick at each corner of the computer (be careful and do it slowly).
    • Once all the corners are slightly lifted, carefully pop off the back cover.
  4. HP Envy x360 15m-cn0012dx  Fan Replacement: stap 4, afbeelding 1 van 3 HP Envy x360 15m-cn0012dx  Fan Replacement: stap 4, afbeelding 2 van 3 HP Envy x360 15m-cn0012dx  Fan Replacement: stap 4, afbeelding 3 van 3
    • Remove the two 4mm screws from the fan using a Phillips #0 screwdriver.
    • Peel the tape off of the multicolor cable bundle connecting the fan to the motherboard.
    • Use the iFixit opening tool to disconnect the connector.
  5. HP Envy x360 15m-cn0012dx  Fan Replacement: stap 5, afbeelding 1 van 2 HP Envy x360 15m-cn0012dx  Fan Replacement: stap 5, afbeelding 2 van 2
    • Peel back the tape from the heatsink.
    • Use the Phillips #0 screwdriver to remove the four captive screws from the heatsink.
    • These screws will stay inside the heatsink while it is removed, simply loosen them until they disengage from the case and the heatsink becomes loose.
  6. HP Envy x360 15m-cn0012dx  Fan Replacement: stap 6, afbeelding 1 van 2 HP Envy x360 15m-cn0012dx  Fan Replacement: stap 6, afbeelding 2 van 2
    • Unlatch the black cable from the plastic guides on the fan.
    • Lift the fan from the laptop case.
Conclusie
Ross Jeseritz
157 Reputatie
1 Handleiding geschreven
UW Stout, Team S1-G3, Schneider-Bateman Spring 2020 Lid van UW Stout, Team S1-G3, Schneider-Bateman Spring 2020
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G3
3 Leden
5 handleidingen geschreven
Één opmerking
You didn't show how to remove the Fan. You removed the Fan and Heat Sink. There's 4 more screws. Finish the job.
philw395 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 67
Altijd: 2,843
