Ga door naar hoofdinhoud
HP Envy x360 15m-bq121dx Cooling Fan Replacement
Wat je nodig hebt
  1. HP Envy x360 15m-bq121dx Cooling Fan Replacement, Cooling Fan: stap 1, afbeelding 1 van 2 HP Envy x360 15m-bq121dx Cooling Fan Replacement, Cooling Fan: stap 1, afbeelding 2 van 2
    • Be sure the computer is powered off.
    • Remove the rubber strip along the top of the backside of the computer.
    • On the back panel of the device, remove the four (4) 2.5 mm screws at the top of the photo using a Phillips #0 screwdriver.
    • Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
  2. HP Envy x360 15m-bq121dx Cooling Fan Replacement: stap 2, afbeelding 1 van 3 HP Envy x360 15m-bq121dx Cooling Fan Replacement: stap 2, afbeelding 2 van 3 HP Envy x360 15m-bq121dx Cooling Fan Replacement: stap 2, afbeelding 3 van 3
    • To remove the back cover, use the spudger to lift up on the edges of the cover.
    • Use a suction cup to assist in lifting the back cover
    • Be sure to not damage any of the electronics on the inside.
  3. HP Envy x360 15m-bq121dx Cooling Fan Replacement: stap 3, afbeelding 1 van 1
    • Use the Philips #0 screwdriver to remove seven 2 mm screws from battery.
  4. HP Envy x360 15m-bq121dx Cooling Fan Replacement: stap 4, afbeelding 1 van 1
    • Lift and pull the front of the battery up and out away from the connector to remove.
  5. HP Envy x360 15m-bq121dx Cooling Fan Replacement: stap 5, afbeelding 1 van 2 HP Envy x360 15m-bq121dx Cooling Fan Replacement: stap 5, afbeelding 2 van 2
    • Using a Philips #0 screwdriver, remove the three 2 mm screws located around the cooling fan as shown in this picture.
    • The fan may have sharp edges so be careful upon removal.
  6. HP Envy x360 15m-bq121dx Cooling Fan Replacement: stap 6, afbeelding 1 van 2 HP Envy x360 15m-bq121dx Cooling Fan Replacement: stap 6, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Remove the connector clip with the tweezers.
  7. HP Envy x360 15m-bq121dx Cooling Fan Replacement: stap 7, afbeelding 1 van 1
    • Remove the four spring loaded screws with a Philips #1 screwdriver.
  8. HP Envy x360 15m-bq121dx Cooling Fan Replacement: stap 8, afbeelding 1 van 2 HP Envy x360 15m-bq121dx Cooling Fan Replacement: stap 8, afbeelding 2 van 2
    • Remove the cooling fan.
Conclusie
Fabien Perez
157 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 37
Altijd: 1,912
