Ga door naar hoofdinhoud
HP Envy x360 15m-bq021dx Wi-Fi Card Replacement
Wat je nodig hebt
  1. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement, Battery: stap 1, afbeelding 1 van 2 HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement, Battery: stap 1, afbeelding 2 van 2
    • On the back panel of the device, remove the four (4) M2.5xL6 screws at the top of the photo using a Phillips #0 screwdriver.
    • Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
  2. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: stap 2, afbeelding 1 van 3 HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: stap 2, afbeelding 2 van 3 HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: stap 2, afbeelding 3 van 3
    • To remove the back cover, use the black spudger to lift up on the edges of the cover.
    • Use a suction cup to assist in lifting the back cover
  3. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: stap 3, afbeelding 1 van 1
    • Use the Philips #0 screwdriver to remove six (6) M2.0x3.2 screws from battery.
  4. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: stap 4, afbeelding 1 van 1
    • Using the Philips #0 screwdriver, remove the final screw from the battery connected to the SSD storage unit.
  5. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: stap 5, afbeelding 1 van 1
    • Lift and pull the front of the battery up and out (away from the connector) to remove.
  6. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement, Cooling Fan: stap 6, afbeelding 1 van 2 HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement, Cooling Fan: stap 6, afbeelding 2 van 2
    • Using a Philips #0 screwdriver, remove the three M2x4 screws located around the cooling fan as shown in this picture.
    • Be careful as the fan might be sharp in some places when removing it.
  7. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: stap 7, afbeelding 1 van 2 HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: stap 7, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Remove the connector clip with the tweezers.
  8. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: stap 8, afbeelding 1 van 1
    • Remove the four spring loaded screws with a Philips #1 screwdriver.
  9. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: stap 9, afbeelding 1 van 2 HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: stap 9, afbeelding 2 van 2
    • Remove the cooling fan.
  10. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement, Motherboard: stap 10, afbeelding 1 van 3 HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement, Motherboard: stap 10, afbeelding 2 van 3 HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement, Motherboard: stap 10, afbeelding 3 van 3
    • Using a Phillips #1, remove the seven M2.0x3.2 screws.
    • Undo the six connections using the blue opening tool.
  11. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: stap 11, afbeelding 1 van 3 HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: stap 11, afbeelding 2 van 3 HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: stap 11, afbeelding 3 van 3
    • Carefully remove the aux port from the frame of the computer as shown.
  12. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: stap 12, afbeelding 1 van 2 HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: stap 12, afbeelding 2 van 2
    • Pull the mother board up and away from frame of the computer.
  13. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement, Wi-Fi Card: stap 13, afbeelding 1 van 3 HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement, Wi-Fi Card: stap 13, afbeelding 2 van 3 HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement, Wi-Fi Card: stap 13, afbeelding 3 van 3
    • Flip the motherboard over.
    • Pull the Wi-Fi card out from the slot.
    • Remember the orientation the Wi-Fi card is in, as it must be inserted in the same way.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 35
Altijd: 861
