Ga door naar hoofdinhoud
HP Envy x360 15m-bq021dx Battery Replacement
Wat je nodig hebt
  1. HP Envy x360 15m-bq021dx Battery Replacement, Battery: stap 1, afbeelding 1 van 2 HP Envy x360 15m-bq021dx Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • On the back panel of the device, remove the four (4) M2.5xL6 screws at the top of the photo using a Phillips #0 screwdriver.
    • Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
  2. HP Envy x360 15m-bq021dx Battery Replacement: stap 2, afbeelding 1 van 3 HP Envy x360 15m-bq021dx Battery Replacement: stap 2, afbeelding 2 van 3 HP Envy x360 15m-bq021dx Battery Replacement: stap 2, afbeelding 3 van 3
    • To remove the back cover, use the black spudger to lift up on the edges of the cover.
    • Use a suction cup to assist in lifting the back cover
  3. HP Envy x360 15m-bq021dx Battery Replacement: stap 3, afbeelding 1 van 1
    • Use the Philips #0 screwdriver to remove six (6) M2.0x3.2 screws from battery.
  4. HP Envy x360 15m-bq021dx Battery Replacement: stap 4, afbeelding 1 van 1
    • Using the Philips #0 screwdriver, remove the final screw from the battery connected to the SSD storage unit.
  5. HP Envy x360 15m-bq021dx Battery Replacement: stap 5, afbeelding 1 van 1
    • Lift and pull the front of the battery up and out (away from the connector) to remove.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Hunter Reihart
506 Reputatie
3 handleidingen geschreven
Één opmerking
Mr. Reihart thank you for this information, could you also say what battery to purchase as a replacement for the 15m -bq.
J r - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 16
Altijd: 2,035
