Ga door naar hoofdinhoud
HP Envy x360 15m-bp111dx Charging Port Replacement
Wat je nodig hebt
  1. HP Envy x360 15m-bp111dx Charging Port Replacement, Back Panel: stap 1, afbeelding 1 van 2 HP Envy x360 15m-bp111dx Charging Port Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Remove the rubber feet to access the screws.
    • Using a Phillips #0 screwdriver, remove the four 7 mm screws.
    • Using a T5 Torx screwdriver, remove the three 5 mm screws.
  2. HP Envy x360 15m-bp111dx Charging Port Replacement: stap 2, afbeelding 1 van 3 HP Envy x360 15m-bp111dx Charging Port Replacement: stap 2, afbeelding 2 van 3 HP Envy x360 15m-bp111dx Charging Port Replacement: stap 2, afbeelding 3 van 3
    • Insert opening picks or an opening tool inside the edge of the chassis to separate the back panel from the rest of the computer.
    • You may hear snapping as the clips are released while you work your way around the perimeter of the computer. This is normal.
    • Remove the back case.
  3. HP Envy x360 15m-bp111dx Charging Port Replacement, Charging Port: stap 3, afbeelding 1 van 3 HP Envy x360 15m-bp111dx Charging Port Replacement, Charging Port: stap 3, afbeelding 2 van 3 HP Envy x360 15m-bp111dx Charging Port Replacement, Charging Port: stap 3, afbeelding 3 van 3
    • Use a Phillips #0 screwdriver to remove the two M2x3.1 screws that secure the speaker in place.
    • Lift and move the speaker to the side.
    • Do not pull too hard on the speaker. It is connected by thin wires that run under the motherboard.
  4. HP Envy x360 15m-bp111dx Charging Port Replacement: stap 4, afbeelding 1 van 2 HP Envy x360 15m-bp111dx Charging Port Replacement: stap 4, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver to remove remove three M2.5x4 screws that secure the hinge.
  5. HP Envy x360 15m-bp111dx Charging Port Replacement: stap 5, afbeelding 1 van 1
    • Use the opening tool to raise the hinge.
    • Then lift the hinge by hand to provide enough clearance to remove the charging port.
    • Be careful when lifting the hinge. The back can be bent and damaged if raised too far.
  6. HP Envy x360 15m-bp111dx Charging Port Replacement: stap 6, afbeelding 1 van 2 HP Envy x360 15m-bp111dx Charging Port Replacement: stap 6, afbeelding 2 van 2
    • Gently slide the charging port connector out of the port, and lift it above the hinge.
  7. HP Envy x360 15m-bp111dx Charging Port Replacement: stap 7, afbeelding 1 van 3 HP Envy x360 15m-bp111dx Charging Port Replacement: stap 7, afbeelding 2 van 3 HP Envy x360 15m-bp111dx Charging Port Replacement: stap 7, afbeelding 3 van 3
    • Grasp the sliding connector on the motherboard and remove it from the socket.
  8. HP Envy x360 15m-bp111dx Charging Port Replacement: stap 8, afbeelding 1 van 1
    • Remove the charging port.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Tori Luongo
268 Reputatie
2 handleidingen geschreven
Clemson, Team 2-2, Hunter Spring 2022 Lid van Clemson, Team 2-2, Hunter Spring 2022
CLEM-HUNTER-S22S2G2
5 Leden
6 handleidingen geschreven
Één opmerking
What is a typical charge for a technician to replace the charging port and what should a typical charging port cost?
Robert Ford - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 22
Altijd: 598
