Ga door naar hoofdinhoud
HP Envy x360 15-u473cl Touch Screen Replacement
Wat je nodig hebt
  1. HP Envy x360 15-u473cl Touch Screen Replacement, Touch Screen: stap 1, afbeelding 1 van 2 HP Envy x360 15-u473cl Touch Screen Replacement, Touch Screen: stap 1, afbeelding 2 van 2
    • Remove the two anti-tamper covers from the bottom corners of the screen using the spudger which will reveal two screws.
    • Remove the two 3mm screws using the J00 Phillips screwdriver.
  2. HP Envy x360 15-u473cl Touch Screen Replacement: stap 2, afbeelding 1 van 1
    • Move the plastic opening tool along the seem while prying up to separate the display housing from the laptop cover.
    • If the touch screen housing is cracked, it may splinter or shatter while separating.
  3. HP Envy x360 15-u473cl Touch Screen Replacement: stap 3, afbeelding 1 van 1
    • Remove the four 3mm screws using the Phillips #00 screwdriver.
  4. HP Envy x360 15-u473cl Touch Screen Replacement: stap 4, afbeelding 1 van 2 HP Envy x360 15-u473cl Touch Screen Replacement: stap 4, afbeelding 2 van 2
    • Lift the white UPC tape using the spudger, and disconnect the the golden connector from the screen.
    • There may be a piece of black tape connecting a bundle of wires to the screen. Remove the piece of black tape if present.
    • Remove the touch screen.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 37
Altijd: 12,844
