Ga door naar hoofdinhoud
HP Envy x360 15-bp143cl Touchpad Replacement
Wat je nodig hebt
  1. HP Envy x360 15-bp143cl Touchpad Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip the laptop over.
    • Peel off the rubber strip closest to the hinges.
  2. HP Envy x360 15-bp143cl Touchpad Replacement: stap 2, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the four 6.5mm screws that were underneath the rubber strip.
  3. HP Envy x360 15-bp143cl Touchpad Replacement: stap 3, afbeelding 1 van 1
    • Use a Torx T5 screwdriver (T5 bit) to remove the three 5mm screws near the bottom edge of the laptop.
  4. HP Envy x360 15-bp143cl Touchpad Replacement: stap 4, afbeelding 1 van 1
    • Lift the back panel to remove it from the laptop.
    • Use an opening tool to pry open the back panel if it does not easily lift apart.
  5. HP Envy x360 15-bp143cl Touchpad Replacement: stap 5, afbeelding 1 van 2 HP Envy x360 15-bp143cl Touchpad Replacement: stap 5, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver (PH1) to remove the seven 4mm screws indicated by the gray arrows on the battery.
  6. HP Envy x360 15-bp143cl Touchpad Replacement: stap 6, afbeelding 1 van 1
    • Pull the battery from the connecting port and lift to remove it from the laptop.
  7. HP Envy x360 15-bp143cl Touchpad Replacement, Touchpad: stap 7, afbeelding 1 van 2 HP Envy x360 15-bp143cl Touchpad Replacement, Touchpad: stap 7, afbeelding 2 van 2
    • Use a spudger to peel the silver tape near the top right side of the touch pad.
  8. HP Envy x360 15-bp143cl Touchpad Replacement: stap 8, afbeelding 1 van 2 HP Envy x360 15-bp143cl Touchpad Replacement: stap 8, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the four 4mm screws securing the bottom metal bar.
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the three 1mm screws securing the top of the touch pad.
  9. HP Envy x360 15-bp143cl Touchpad Replacement: stap 9, afbeelding 1 van 1
    • Remove the metal cover by lifting it away from the laptop.
  10. HP Envy x360 15-bp143cl Touchpad Replacement: stap 10, afbeelding 1 van 2 HP Envy x360 15-bp143cl Touchpad Replacement: stap 10, afbeelding 2 van 2
    • Lift the bottom side of the touch pad.
    • Lift the black tab that secures the touch pad connecting cable to the laptop.
    • Pull the cable from the touch pad connecting port.
  11. HP Envy x360 15-bp143cl Touchpad Replacement: stap 11, afbeelding 1 van 2 HP Envy x360 15-bp143cl Touchpad Replacement: stap 11, afbeelding 2 van 2
    • Lift the touch pad to remove it.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Spencer Berkins
577 Reputatie
4 handleidingen geschreven
Cal Poly, Team S12-G3, Regan Fall 2019 Lid van Cal Poly, Team S12-G3, Regan Fall 2019
CPSU-REGAN-F19S12G3
3 Leden
6 handleidingen geschreven
Één opmerking
Thanks now have to find one on E-bay….or?
Michael - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 26
Altijd: 1,510
