Inleiding
The power jack on the HP Envy x360 13-y013cl can wear out or become dislodged over time. This guide shows a complete replacement procedure for the power jack. The power supply is critical to the overall functionality of the computer, delivering charge to the battery. Before using this guide, check for foreign objects lodged in the port. Before starting the guide, ensure to power off the device and disconnect the power jack.
Wat je nodig hebt
Unscrew and remove the 7.8 mm screws with a T5 screwdriver.
Use a plastic opening tool to pry the bottom cover off the laptop.
