Ga door naar hoofdinhoud
HP Envy x360 13-y013cl Power Jack Replacement
Wat je nodig hebt
  1. HP Envy x360 13-y013cl Power Jack Replacement, Power Jack: stap 1, afbeelding 1 van 3 HP Envy x360 13-y013cl Power Jack Replacement, Power Jack: stap 1, afbeelding 2 van 3 HP Envy x360 13-y013cl Power Jack Replacement, Power Jack: stap 1, afbeelding 3 van 3
    • Unscrew and remove the 7.8 mm screws with a T5 screwdriver.
    • Use a plastic opening tool to pry the bottom cover off the laptop.
  2. HP Envy x360 13-y013cl Power Jack Replacement: stap 2, afbeelding 1 van 1
    • Locate the copper-colored heat sync.
    • Use a JIS #0 screwdriver to remove the four 2.7 mm screws that secure the heatsink.
    • After removing the screws, lift the heatsink directly off the computer.
  3. HP Envy x360 13-y013cl Power Jack Replacement: stap 3, afbeelding 1 van 2 HP Envy x360 13-y013cl Power Jack Replacement: stap 3, afbeelding 2 van 2
    • Locate the right hinge just above the fan.
    • Use a JIS #0 screwdriver to remove two 4 mm screws from the hinge display assembly hinge.
    • Use a JIS #0 screwdriver to remove the 4.2 mm screw from directly below the power jack.
  4. HP Envy x360 13-y013cl Power Jack Replacement: stap 4, afbeelding 1 van 2 HP Envy x360 13-y013cl Power Jack Replacement: stap 4, afbeelding 2 van 2
    • Using the plastic black spudger, pry the hinge back as shown with the red arrow.
    • Continuing with the black plastic spudger, dislodge the power supply's metal frame from the computer.
  5. HP Envy x360 13-y013cl Power Jack Replacement: stap 5, afbeelding 1 van 1
    • Disconnect the EH-JST connector and remove the entire power supply from computer (metal frame, wire, and connector).
Conclusie
Petersee
382 Reputatie
3 handleidingen geschreven
IUPUI, Team 3-2, Harley Spring 2023 Lid van IUPUI, Team 3-2, Harley Spring 2023
IUPUI-HARLEY-S23S3G2
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 16
Altijd: 303
