Ga door naar hoofdinhoud
HP Envy x2 13-j002dx Screen Replacement
Wat je nodig hebt
  1. HP Envy x2 13-j002dx Screen Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove five 4mm Phillips #0 screws securing the lower case to the HP Envy x2 13-j002dx.
  2. HP Envy x2 13-j002dx Screen Replacement: stap 2, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the two 3.5 mm screws from the bottom of the device—one on each side of the keyboard dock.
  3. HP Envy x2 13-j002dx Screen Replacement: stap 3, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Use a pair of tweezers to remove the screw covers on the bottom of the device.
    • Use a Phillips #0 screwdriver to remove the two 4mm screws.
  4. HP Envy x2 13-j002dx Screen Replacement: stap 4, afbeelding 1 van 2 HP Envy x2 13-j002dx Screen Replacement: stap 4, afbeelding 2 van 2
    • Use an opening pick to remove the plastic cover above the back stand.
    • Pry the cover off.
    • Use a Phillips #0 screwdriver to remove the four 4 mm screws.
  5. HP Envy x2 13-j002dx Screen Replacement: stap 5, afbeelding 1 van 1
    • Use an opening pick and a prying tool, and go around the device to remove the back cover from the rest of the assembly.
  6. HP Envy x2 13-j002dx Screen Replacement: stap 6, afbeelding 1 van 1
    • Unplug the battery from the motherboard.
  7. HP Envy x2 13-j002dx Screen Replacement: stap 7, afbeelding 1 van 2 HP Envy x2 13-j002dx Screen Replacement: stap 7, afbeelding 2 van 2
    • Carefully pull up on the battery connector from the speaker.
    • Use a pair of tweezers and remove the taped down wire for the speaker.
    • Use a Phillips #00 screwdriver to remove the seven 3mm screws around the battery.
  8. HP Envy x2 13-j002dx Screen Replacement: stap 8, afbeelding 1 van 1
    • Carefully lift up and remove the battery.
  9. HP Envy x2 13-j002dx Screen Replacement, Motherboard: stap 9, afbeelding 1 van 1
    • Before removing the motherboard, clear away any dust, and ensure that the battery is already removed.
  10. HP Envy x2 13-j002dx Screen Replacement: stap 10, afbeelding 1 van 2 HP Envy x2 13-j002dx Screen Replacement: stap 10, afbeelding 2 van 2
    • Using a Phillips #0 screwdriver, remove the three 3.8 mm screws along the edge of the motherboard.
  11. HP Envy x2 13-j002dx Screen Replacement: stap 11, afbeelding 1 van 2 HP Envy x2 13-j002dx Screen Replacement: stap 11, afbeelding 2 van 2
    Koop
    • Disconnect the cable connectors from the motherboard. This can be done with either tweezers or with your fingers.
  12. HP Envy x2 13-j002dx Screen Replacement: stap 12, afbeelding 1 van 2 HP Envy x2 13-j002dx Screen Replacement: stap 12, afbeelding 2 van 2
    • Using the Phillips #0 screwdriver, remove the 3.2mm screws within the copper rings in the circuit board.
    • Using the Phillips #0 screwdriver, remove the 2.5mm and 4.25mm black screws on the motherboard.
  13. HP Envy x2 13-j002dx Screen Replacement: stap 13, afbeelding 1 van 1
    • Once the screws and cables are disconnected and removed, remove the motherboard from the frame.
  14. HP Envy x2 13-j002dx Screen Replacement, Screen: stap 14, afbeelding 1 van 1
    • Once the battery and motherboard are removed, the screen unit should offer little resistance. Remove the screen from the base.
Conclusie
Colton Moon
241 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 17
Altijd: 715
