Ga door naar hoofdinhoud
HP Envy x2 13-j002dx Battery Replacement
Wat je nodig hebt
  1. HP Envy x2 13-j002dx Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove five 4mm Phillips #0 screws securing the lower case to the HP Envy x2 13-j002dx.
  2. HP Envy x2 13-j002dx Battery Replacement: stap 2, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the two 3.5 mm screws from the bottom of the device—one on each side of the keyboard dock.
  3. HP Envy x2 13-j002dx Battery Replacement: stap 3, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Use a pair of tweezers to remove the screw covers on the bottom of the device.
    • Use a Phillips #0 screwdriver to remove the two 4mm screws.
  4. HP Envy x2 13-j002dx Battery Replacement: stap 4, afbeelding 1 van 2 HP Envy x2 13-j002dx Battery Replacement: stap 4, afbeelding 2 van 2
    • Use an opening pick to remove the plastic cover above the back stand.
    • Pry the cover off.
    • Use a Phillips #0 screwdriver to remove the four 4 mm screws.
  5. HP Envy x2 13-j002dx Battery Replacement: stap 5, afbeelding 1 van 1
    • Use an opening pick and a prying tool, and go around the device to remove the back cover from the rest of the assembly.
  6. HP Envy x2 13-j002dx Battery Replacement: stap 6, afbeelding 1 van 1
    • Unplug the battery from the motherboard.
  7. HP Envy x2 13-j002dx Battery Replacement: stap 7, afbeelding 1 van 2 HP Envy x2 13-j002dx Battery Replacement: stap 7, afbeelding 2 van 2
    • Carefully pull up on the battery connector from the speaker.
    • Use a pair of tweezers and remove the taped down wire for the speaker.
    • Use a Phillips #00 screwdriver to remove the seven 3mm screws around the battery.
  8. HP Envy x2 13-j002dx Battery Replacement: stap 8, afbeelding 1 van 1
    • Carefully lift up and remove the battery.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Één opmerking
For step 2, when I was taking the screws out, they were held in by the magnets that were on either side of them making it difficult to remove. I ended up having to use another magnet to get them out.
Reed Jochimsen - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 24
Altijd: 1,912
