Ga door naar hoofdinhoud
HP Envy m6-k022dx RAM Replacement
Wat je nodig hebt
  1. HP Envy m6-k022dx RAM Replacement, Lower Case: stap 1, afbeelding 1 van 1
    • There are 12 phillips head screws which need to be unscrewed before removing the backplate of the laptop.
  2. HP Envy m6-k022dx RAM Replacement: stap 2, afbeelding 1 van 1
    • Next, use a size PH1 Philips head screw driver to remove the screws.
  3. HP Envy m6-k022dx RAM Replacement: stap 3, afbeelding 1 van 1
    • Then, use a prying tool to help uncouple the backplate.
  4. HP Envy m6-k022dx RAM Replacement: stap 4, afbeelding 1 van 1
    • Finally, use both hands to lift up and take off the back plate of the computer.
  5. HP Envy m6-k022dx RAM Replacement, RAM: stap 5, afbeelding 1 van 1
    • The RAM sticks are located in the right upper corner of the laptop of the laptop.
  6. HP Envy m6-k022dx RAM Replacement: stap 6, afbeelding 1 van 1
    • There are two clips holding each RAM stick in place; one on each side of each stick.
    • Gently pull each clips outwards, away from the RAM sticks. They will easily unclip from the RAM.
  7. HP Envy m6-k022dx RAM Replacement: stap 7, afbeelding 1 van 1
    • Grab the top of the RAM stick and pull directly up, towards the outer edge of the laptop.
    • The RAM sticks will slide out from their slots relatively easily. They are now ready to be replaced.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Anthony Stubbs
182 Reputatie
1 Handleiding geschreven
USF Tampa, Team S13-G6, Cagle Spring 2017 Lid van USF Tampa, Team S13-G6, Cagle Spring 2017
USFT-CAGLE-S17S13G6
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 1,117
