Ga door naar hoofdinhoud
HP Envy m6-k022dx CMOS Battery Replacement
Wat je nodig hebt
  1. HP Envy m6-k022dx CMOS Battery Replacement, Lower Case: stap 1, afbeelding 1 van 1
    • There are 12 phillips head screws which need to be unscrewed before removing the backplate of the laptop.
  2. HP Envy m6-k022dx CMOS Battery Replacement: stap 2, afbeelding 1 van 1
    • Next, use a size PH1 Philips head screw driver to remove the screws.
  3. HP Envy m6-k022dx CMOS Battery Replacement: stap 3, afbeelding 1 van 1
    • Then, use a prying tool to help uncouple the backplate.
  4. HP Envy m6-k022dx CMOS Battery Replacement: stap 4, afbeelding 1 van 1
    • Finally, use both hands to lift up and take off the back plate of the computer.
  5. HP Envy m6-k022dx CMOS Battery Replacement, CMOS Battery: stap 5, afbeelding 1 van 1
    • There is a power cord connecting the CMOS battery to the motherboard. Disconnect this cord by gently pulling it up, towards the edge of the device.
  6. HP Envy m6-k022dx CMOS Battery Replacement: stap 6, afbeelding 1 van 1
    • Once the connecting cord has been disconnected, gently lift the battery directly up, above the device.
    • The CMOS battery is now completely removed, and ready to be replaced.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Kareem Rigaud
403 Reputatie
3 handleidingen geschreven
USF Tampa, Team S13-G6, Cagle Spring 2017 Lid van USF Tampa, Team S13-G6, Cagle Spring 2017
USFT-CAGLE-S17S13G6
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 23
Altijd: 2,816
