Ga door naar hoofdinhoud
HP Envy m6-k015dx RAM Replacement
Wat je nodig hebt
    • Shut down the computer
    • Remove all external devices
    • Unplug the AC adapter
    • Close the computer
    • Turn it upside down
    • Remove the 12 screws from the bottom.
    • Gently remove the service cover
    • Disconnect the battery cable from the motherboard.
    • Remove the 4 screws that hold the battery.
    • Gently lift the battery out of the computer.
    • Carefully pull the retaining metal tabs at each side of the RAM stick to the side
    • Pull the RAM stick at a thirty degree inclination to remove it
Conclusie
Chuka
621 Reputatie
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 33
