Ga door naar hoofdinhoud
HP Envy m6-1225dx Optical Drive Replacement
Wat je nodig hebt
  1. HP Envy m6-1225dx Optical Drive Replacement, Optical Drive: stap 1, afbeelding 1 van 1
    • Flip the laptop over onto it's top with the back facing you
  2. HP Envy m6-1225dx Optical Drive Replacement: stap 2, afbeelding 1 van 3 HP Envy m6-1225dx Optical Drive Replacement: stap 2, afbeelding 2 van 3 HP Envy m6-1225dx Optical Drive Replacement: stap 2, afbeelding 3 van 3
    • Pull the slide release tab to the left to free the battery.
    • Once the slide release is all the way over, a red icon should be visible.
    • As you pull the tab, the bottom edge of the battery should start to come up.
  3. HP Envy m6-1225dx Optical Drive Replacement: stap 3, afbeelding 1 van 1
    • Remove the battery
  4. HP Envy m6-1225dx Optical Drive Replacement: stap 4, afbeelding 1 van 2 HP Envy m6-1225dx Optical Drive Replacement: stap 4, afbeelding 2 van 2
    • Remove the center screw using a Phillips #1 screwdriver.
  5. HP Envy m6-1225dx Optical Drive Replacement: stap 5, afbeelding 1 van 2 HP Envy m6-1225dx Optical Drive Replacement: stap 5, afbeelding 2 van 2
    • Move the battery slide release latch to the side while pulling the service cover forward.
    • Pull the service cover straight up and out to remove.
  6. HP Envy m6-1225dx Optical Drive Replacement: stap 6, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver to remove the single screw holding the optical drive
  7. HP Envy m6-1225dx Optical Drive Replacement: stap 7, afbeelding 1 van 2 HP Envy m6-1225dx Optical Drive Replacement: stap 7, afbeelding 2 van 2
    • Use a spudger to apply pressure to the tab, while simultaneously pulling out the optical drive.
    • While the images show the tab being pushed out with a screwdriver, we recommend using an ESD-safe instrument instead!
  8. HP Envy m6-1225dx Optical Drive Replacement: stap 8, afbeelding 1 van 1
    • Pull the optical drive out of the base of the laptop.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 5
Altijd: 167
