Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
CPU Cooling Fan Part Number
686901-001 DC28000BFS0
The CPU Cooling Fan allows for continuous cooling of the CPU also known as the brain of a computer inside a laptop to not overheat and burn the user.
This CPU Cooling Fan can be prone to issues of overheating due to clogging or a faulty fan. If you believe the fan is not faulty and only needs cleaning, you can remove the fan and cleanse it with a computer duster.
This guide will go step-by-step on how to remove a clogged or faulty cooling fan.
Check out the Troubleshooting guide for other issues that could be related to the fan.
CAUTION: Placing the computer on a cloth surface such as your lap, a bed, or a couch cushion, can restrict or completely block the airflow. Prolonged air restriction causes overheating and potential damage.
CAUTION: DO NOT continue to use the computer when a fan is not working correctly. Overtime, exposure to consistently high temperatures can damage other important internal components.
Onderdelen
Geen onderdelen opgegeven.
  1. Flip the laptop over onto it's top with the back facing you
    • Flip the laptop over onto it's top with the back facing you
  2. Pull the slide release tab to the left to free the battery. Once the slide release is all the way over, a red icon should be visible. As you pull the tab, the bottom edge of the battery should start to come up.
    • Pull the slide release tab to the left to free the battery.
    • Once the slide release is all the way over, a red icon should be visible.
    • As you pull the tab, the bottom edge of the battery should start to come up.
  3. Remove the battery
    • Remove the battery
  4. Remove the center screw using a Phillips #1 screwdriver. Remove the center screw using a Phillips #1 screwdriver.
    • Remove the center screw using a Phillips #1 screwdriver.
  5. Move the battery slide release latch to the side while pulling the service cover forward. Pull the service cover straight up and out to remove.
    • Move the battery slide release latch to the side while pulling the service cover forward.
    • Pull the service cover straight up and out to remove.
  6. Use a Phillips #1 screwdriver to remove the single screw holding the optical drive
    • Use a Phillips #1 screwdriver to remove the single screw holding the optical drive
  7. SLA DE UPGRADE OVER
    Bespaar door het te repareren met een alles-in-één kit.
    Koop iPhone-reparatiekits
    SLA DE UPGRADE OVER
  8. Use a spudger to apply pressure to the tab, while simultaneously pulling out the optical drive. While the images show the tab being pushed out with a screwdriver, we recommend using an ESD-safe instrument instead!
    • Use a spudger to apply pressure to the tab, while simultaneously pulling out the optical drive.
    • While the images show the tab being pushed out with a screwdriver, we recommend using an ESD-safe instrument instead!
  9. Pull the optical drive out of the base of the laptop.
    • Pull the optical drive out of the base of the laptop.
  10. Remove the four Phillips #1 screws from the hard drive bracket. Remove the four Phillips #1 screws from the hard drive bracket.
    • Remove the four Phillips #1 screws from the hard drive bracket.
  11. Disconnect the cable from the side of the hard drive and move to the side.
    • Disconnect the cable from the side of the hard drive and move to the side.
    • Remove the hard drive.
    • Our laptop did not have a hard drive when we disassembled it
  12. Remove the two Phillips #1 screws that secure the keyboard to the laptop.
    • Remove the two Phillips #1 screws that secure the keyboard to the laptop.
  13. Make the device stand onto its left side with the device open. Turn the laptop and look into the empty battery slot for two release holes. Insert a metal spudger into the release holes and apply pressure to the back of the keyboard until it comes loose of the laptop.
    • Make the device stand onto its left side with the device open.
    • Turn the laptop and look into the empty battery slot for two release holes.
    • Insert a metal spudger into the release holes and apply pressure to the back of the keyboard until it comes loose of the laptop.
  14. Gently lift the keyboard away from the laptop. Lift up the cable holder and remove the cable connection from the base of the laptop.
    • Gently lift the keyboard away from the laptop.
    • Lift up the cable holder and remove the cable connection from the base of the laptop.
    • Lift up the locking tab of the ZIF connector and remove the keyboard backlight cable.
    • The keyboard backlight cable is only present on select models.
  15. Remove the 13 screws on the bottom of the laptop that secure the top cover using a Phillips #1 screwdriver. Remove the 13 screws on the bottom of the laptop that secure the top cover using a Phillips #1 screwdriver.
    • Remove the 13 screws on the bottom of the laptop that secure the top cover using a Phillips #1 screwdriver.
  16. Disconnect Power button board cable using a pair tweezers. Disconnect Touch Pad button board cable using a pair tweezers. Disconnect Fingerprint reader board cable using a pair tweezers.
    • Disconnect Power button board cable using a pair tweezers.
    • Disconnect Touch Pad button board cable using a pair tweezers.
    • Disconnect Fingerprint reader board cable using a pair tweezers.
    • Disconnect Right speaker cable using a pair tweezers.
    • Remove the 4 screws using a Phillips #1 screwdriver.
    • Apply force to the base of the cover to pop if off from the laptop base.
    • Be sure the cable for the right speaker doesn't get caught on the cover as it is removed or the speaker could be damaged.
  17. Remove the two screws holding the cooling fan down with a Phillips #1 screwdriver. Disconnect the cooling fan cable using a pair tweezers. Gently lift the cooling fan.
    • Remove the two screws holding the cooling fan down with a Phillips #1 screwdriver.
    • Disconnect the cooling fan cable using a pair tweezers.
    • Gently lift the cooling fan.
Conclusie
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 48
