Ga door naar hoofdinhoud
HP Envy m6-1105dx WLAN Card Replacement
Wat je nodig hebt
  1. HP Envy m6-1105dx WLAN Card Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the computer completely off.
    • Disconnect any devices you have on it.
    • Turn the computer upside down on a flat surface.
  2. HP Envy m6-1105dx WLAN Card Replacement: stap 2, afbeelding 1 van 1
    • Push the battery release latch with one hand.
    • Grab the battery with the other hand.
    • Lift out on an angle.
  3. HP Envy m6-1105dx WLAN Card Replacement, WLAN Card: stap 3, afbeelding 1 van 1
    • Release the screw in the center of the service cover.
    • Slide the battery release latch and pull cover towards you.
    • Lift cover off.
  4. HP Envy m6-1105dx WLAN Card Replacement: stap 4, afbeelding 1 van 2 HP Envy m6-1105dx WLAN Card Replacement: stap 4, afbeelding 2 van 2
    • Use a JIS #0 screwdriver to unscrew the small cover where the WLAN card is.
    • The screw does not come out all the way so unscrew it as far as you can then try to life the cover.
  5. HP Envy m6-1105dx WLAN Card Replacement: stap 5, afbeelding 1 van 3 HP Envy m6-1105dx WLAN Card Replacement: stap 5, afbeelding 2 van 3 HP Envy m6-1105dx WLAN Card Replacement: stap 5, afbeelding 3 van 3
    • Use a plastic opening tool to gently disconnect the WLAN antenna cables.
  6. HP Envy m6-1105dx WLAN Card Replacement: stap 6, afbeelding 1 van 2 HP Envy m6-1105dx WLAN Card Replacement: stap 6, afbeelding 2 van 2
    • Remove the two PM2.0×3.0 screws that secure the WLAN module to the base using the JIS #0 screwdriver.
    • Using two fingers, grab the sides of the WLAN card and slowly pull it out.
Conclusie
Ian Mwalago
303 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team S1-G5, Valliere Fall 2018 Lid van UMass Dartmouth, Team S1-G5, Valliere Fall 2018
UMASSD-VALLIERE-F18S1G5
5 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 603
