Ga door naar hoofdinhoud
HP Envy m6-1105dx RAM Replacement
  1. HP Envy m6-1105dx RAM Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the computer completely off.
    • Disconnect any devices you have on it.
    • Turn the computer upside down on a flat surface.
  2. HP Envy m6-1105dx RAM Replacement: stap 2, afbeelding 1 van 1
    • Push the battery release latch with one hand.
    • Grab the battery with the other hand.
    • Lift out on an angle.
  3. HP Envy m6-1105dx RAM Replacement, RAM: stap 3, afbeelding 1 van 1
    • Release the screw in the center of the service cover.
    • Slide the battery release latch and pull cover towards you.
    • Lift cover off.
  4. HP Envy m6-1105dx RAM Replacement: stap 4, afbeelding 1 van 2 HP Envy m6-1105dx RAM Replacement: stap 4, afbeelding 2 van 2
    • Push the silver levers on either side of the memory module away from the module.
    • Remove the memory module by gently pulling it on an angle away from the slot.
Conclusie
Melody Veldorale
305 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team S1-G5, Valliere Fall 2018 Lid van UMass Dartmouth, Team S1-G5, Valliere Fall 2018
UMASSD-VALLIERE-F18S1G5
5 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 393
