Inleiding
Use this guide to replace a faulty service cover on your HP Envy dv7t-7200 if the back cover has been broken, damaged, or will not stay on any longer.
Wat je nodig hebt
Place the computer on its top on a flat surface with the hinges facing away from you.
Using a Phillips #01 screwdriver, remove the Phillips PM2.5×5.5 screw on the service cover.
Één andere persoon heeft deze handleiding voltooid.
