Ga door naar hoofdinhoud
HP Envy dv7t-7200 RAM Replacement
Wat je nodig hebt
  1. HP Envy dv7t-7200 RAM Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the power off and disconnect all cables and cords from the laptop.
    • Place the computer on its top on a flat surface with the hinges facing away from you.
  2. HP Envy dv7t-7200 RAM Replacement: stap 2, afbeelding 1 van 3 HP Envy dv7t-7200 RAM Replacement: stap 2, afbeelding 2 van 3 HP Envy dv7t-7200 RAM Replacement: stap 2, afbeelding 3 van 3
    • Slide the battery release latch to the left which is located on the right-hand side of the battery.
  3. HP Envy dv7t-7200 RAM Replacement: stap 3, afbeelding 1 van 1
    • Tilt the battery away from you and lift out.
  4. HP Envy dv7t-7200 RAM Replacement, Service Cover: stap 4, afbeelding 1 van 1
    • Using a Phillips #01 screwdriver, remove the Phillips PM2.5×5.5 screw on the service cover.
    • This screw does not come out of the service cover completely once loosened.
  5. HP Envy dv7t-7200 RAM Replacement: stap 5, afbeelding 1 van 2 HP Envy dv7t-7200 RAM Replacement: stap 5, afbeelding 2 van 2
    • Slide the service cover toward the front of the laptop.
    • Lift the service cover to remove it from the laptop.
  6. HP Envy dv7t-7200 RAM Replacement, RAM: stap 6, afbeelding 1 van 2 HP Envy dv7t-7200 RAM Replacement, RAM: stap 6, afbeelding 2 van 2
    • Press down and away from the ram cards on the tabs surrounding the ram cards.
  7. HP Envy dv7t-7200 RAM Replacement: stap 7, afbeelding 1 van 2 HP Envy dv7t-7200 RAM Replacement: stap 7, afbeelding 2 van 2
    • The first ram card will pop up, and now you will slide it out of its slot.
  8. HP Envy dv7t-7200 RAM Replacement: stap 8, afbeelding 1 van 3 HP Envy dv7t-7200 RAM Replacement: stap 8, afbeelding 2 van 3 HP Envy dv7t-7200 RAM Replacement: stap 8, afbeelding 3 van 3
    • Repeat this process for the second ram card.
Conclusie
Krystal
882 Reputatie
8 handleidingen geschreven
UW Tacoma, Team S3-G3, Liner Fall 2017 Lid van UW Tacoma, Team S3-G3, Liner Fall 2017
UWT-LINER-F17S3G3
5 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 174
