Ga door naar hoofdinhoud
HP Envy dv6-7363cl Wi-fi Card Replacement
Wat je nodig hebt
  1. HP Envy dv6-7363cl Wi-fi Card Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip the device upside-down so that its bottom is facing up.
  2. HP Envy dv6-7363cl Wi-fi Card Replacement: stap 2, afbeelding 1 van 1
    • Push the lever underneath the battery to the left.
  3. HP Envy dv6-7363cl Wi-fi Card Replacement: stap 3, afbeelding 1 van 2 HP Envy dv6-7363cl Wi-fi Card Replacement: stap 3, afbeelding 2 van 2
    • Lift the battery up out of its socket.
  4. HP Envy dv6-7363cl Wi-fi Card Replacement, Wi-Fi Card: stap 4, afbeelding 1 van 1
    • After removing the battery, remove the circled screw.
  5. HP Envy dv6-7363cl Wi-fi Card Replacement: stap 5, afbeelding 1 van 1
    • Remove the back cover.
  6. HP Envy dv6-7363cl Wi-fi Card Replacement: stap 6, afbeelding 1 van 1
    • With the back cover removed, locate the Wi-Fi card which is positioned next to the Beats logo.
  7. HP Envy dv6-7363cl Wi-fi Card Replacement: stap 7, afbeelding 1 van 2 HP Envy dv6-7363cl Wi-fi Card Replacement: stap 7, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Carefully remove gold-headed, black wires from Wi-Fi card with tweezers.
  8. HP Envy dv6-7363cl Wi-fi Card Replacement: stap 8, afbeelding 1 van 2 HP Envy dv6-7363cl Wi-fi Card Replacement: stap 8, afbeelding 2 van 2
    • After removing wires, remove circled screws from card.
    • Note: Laptop shown only has one screw holding in Wi-Fi card. Some models may have both.
  9. HP Envy dv6-7363cl Wi-fi Card Replacement: stap 9, afbeelding 1 van 2 HP Envy dv6-7363cl Wi-fi Card Replacement: stap 9, afbeelding 2 van 2
    • Wi-Fi card will raise out of device when screw is removed.
    • Gently pull card to the right to remove from device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
dylananthony
564 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team S2-G5, Bernier Spring 2018 Lid van UMass Dartmouth, Team S2-G5, Bernier Spring 2018
UMASSD-BERNIER-S18S2G5
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 364
