Ga door naar hoofdinhoud
HP Envy Ultrabook 4-1015dx Cooling Fan Replacement
Wat je nodig hebt
  1. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure that the device is turned off and that all external devices are removed.
  2. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: stap 2, afbeelding 1 van 1
    • Flip the device over so that the back plate is facing upwards.
  3. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: stap 3, afbeelding 1 van 2 HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: stap 3, afbeelding 2 van 2
    • Using a small (size 0) Phillips head screwdriver, remove the twelve 5.5 mm external Phillips head screws that connect the back plate to the device.
    • Make sure to set the screws aside in a safe place so that you do not lose them, as they will be needed to reattach the backplate later.
  4. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: stap 4, afbeelding 1 van 2 HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: stap 4, afbeelding 2 van 2
    • Using the plastic opening tool, gently pry off the back plate from the device.
  5. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: stap 5, afbeelding 1 van 2 HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: stap 5, afbeelding 2 van 2
    • The large black box with the white warning images is the battery.
    • Move the ribbon cable so that it is no longer on top of the battery.
  6. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: stap 6, afbeelding 1 van 2 HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: stap 6, afbeelding 2 van 2
    • Using a small (size 0) Phillips head screwdriver, remove the three 3.5 mm Phillips head internal screws that hold the battery in place.
    • Make sure not to lose these internal screws; they will later be used to reattach the battery.
  7. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: stap 7, afbeelding 1 van 2 HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: stap 7, afbeelding 2 van 2
    • Lift up the battery and remove it from the slot as shown.
  8. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: stap 8, afbeelding 1 van 3 HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: stap 8, afbeelding 2 van 3 HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: stap 8, afbeelding 3 van 3
    • Use the plastic opening tool to disconnect the battery cable.
  9. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: stap 9, afbeelding 1 van 1
    • Lift up the battery and remove it from the device.
  10. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement, Cooling Fan: stap 10, afbeelding 1 van 2 HP Envy Ultrabook 4-1015dx Cooling Fan Replacement, Cooling Fan: stap 10, afbeelding 2 van 2
    • Remove the screws that secure the top cover of the fan.
  11. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: stap 11, afbeelding 1 van 1
    • Lift the fan up and remove it gently.
  12. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: stap 12, afbeelding 1 van 1
    • Remove the fan cable with the plastic opening tool.
  13. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: stap 13, afbeelding 1 van 1
    • Remove the fan from the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Eve Wyman
139 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team S1-G3, Valliere Fall 2018 Lid van UMass Dartmouth, Team S1-G3, Valliere Fall 2018
UMASSD-VALLIERE-F18S1G3
5 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 167
