Wat je nodig hebt
Turn the laptop over so that the bottom is facing up
Using the J0 screwdriver, unscrew all 12 M2.5x5.5 screws from the back panel.
Use the J0 screwdriver to remove the two M2.0x3.0 screws holding in the cooling fan
Use the J1 screwdriver to remove the three M2.5x2.5 screws on the SD card reader.
Remove the SD card reader and set it aside.
Bijna klaar!
Conclusie
