Ga door naar hoofdinhoud
HP Envy TouchSmart 4-1215dx Motherboard Replacement
Wat je nodig hebt
  1. HP Envy TouchSmart 4-1215dx Motherboard Replacement, Back Panel Assembly: stap 1, afbeelding 1 van 2 HP Envy TouchSmart 4-1215dx Motherboard Replacement, Back Panel Assembly: stap 1, afbeelding 2 van 2
    • Remove the thirteen Phillips #0 screws.
  2. HP Envy TouchSmart 4-1215dx Motherboard Replacement: stap 2, afbeelding 1 van 2 HP Envy TouchSmart 4-1215dx Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Pull the panel up and off to remove from the laptop.
  3. HP Envy TouchSmart 4-1215dx Motherboard Replacement, Battery: stap 3, afbeelding 1 van 2 HP Envy TouchSmart 4-1215dx Motherboard Replacement, Battery: stap 3, afbeelding 2 van 2
    • Unplug the battery from the motherboard.
  4. HP Envy TouchSmart 4-1215dx Motherboard Replacement: stap 4, afbeelding 1 van 2 HP Envy TouchSmart 4-1215dx Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Remove the three Phillips #0 screws from the battery.
    • Pull the battery out of the laptop.
  5. HP Envy TouchSmart 4-1215dx Motherboard Replacement, Fan: stap 5, afbeelding 1 van 1
    • Unplug the fan from the motherboard.
  6. HP Envy TouchSmart 4-1215dx Motherboard Replacement: stap 6, afbeelding 1 van 2 HP Envy TouchSmart 4-1215dx Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Remove the four Phillips #0 screws holding in the fan.
    • Pull out the fan.
  7. HP Envy TouchSmart 4-1215dx Motherboard Replacement, Wi-Fi Card: stap 7, afbeelding 1 van 2 HP Envy TouchSmart 4-1215dx Motherboard Replacement, Wi-Fi Card: stap 7, afbeelding 2 van 2
    • Remove the single screw from the Wi-Fi card using a Phillips #0 screwdriver.
    • Pull the Wi-Fi card out of its slot.
  8. HP Envy TouchSmart 4-1215dx Motherboard Replacement, Heat Sink: stap 8, afbeelding 1 van 1
    • Remove four screws from the heat sink using a Phillips #0 screwdriver.
  9. HP Envy TouchSmart 4-1215dx Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Gently lift the heat sink from the motherboard.
  10. HP Envy TouchSmart 4-1215dx Motherboard Replacement, Motherboard: stap 10, afbeelding 1 van 1
    • Remove the remaining from the motherboard with a Phillips #0 screwdriver.
  11. HP Envy TouchSmart 4-1215dx Motherboard Replacement: stap 11, afbeelding 1 van 3 HP Envy TouchSmart 4-1215dx Motherboard Replacement: stap 11, afbeelding 2 van 3 HP Envy TouchSmart 4-1215dx Motherboard Replacement: stap 11, afbeelding 3 van 3
    • Disconnect the remaining cables from the motherboard by gently tugging on the pull tabs or the edges of the connectors that sit in the terminals.
  12. HP Envy TouchSmart 4-1215dx Motherboard Replacement: stap 12, afbeelding 1 van 2 HP Envy TouchSmart 4-1215dx Motherboard Replacement: stap 12, afbeelding 2 van 2
    • Gently lift the motherboard from the housing to remove it from the laptop.
Conclusie
Cassie Hunter
97 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 142
