Ga door naar hoofdinhoud
HP Envy TouchSmart 4-1215dx Display Replacement
Wat je nodig hebt
  1. HP Envy TouchSmart 4-1215dx Display Replacement, Display: stap 1, afbeelding 1 van 1
    • Remove both 3 mm screws at the bottom of the display using a Phillips #0 screwdriver.
  2. HP Envy TouchSmart 4-1215dx Display Replacement: stap 2, afbeelding 1 van 2 HP Envy TouchSmart 4-1215dx Display Replacement: stap 2, afbeelding 2 van 2
    • Using an iFixit opening tool, pry the screen from the back panel.
    • Remove the back panel.
  3. HP Envy TouchSmart 4-1215dx Display Replacement: stap 3, afbeelding 1 van 1
    • Close the laptop so the front is facing you.
    • Remove the four 3 mm screws from the two brackets at the front using a Phillips #0 screwdriver.
    • Remove the brackets.
  4. HP Envy TouchSmart 4-1215dx Display Replacement: stap 4, afbeelding 1 van 3 HP Envy TouchSmart 4-1215dx Display Replacement: stap 4, afbeelding 2 van 3 HP Envy TouchSmart 4-1215dx Display Replacement: stap 4, afbeelding 3 van 3
    • Remove the 3 mm screws from the back brackets using a Phillips #0 screwdriver.
    • Remove the 1 mm screws with a Phillips #00 screwdriver.
    • Lift up the display until the brackets are sticking straight up.
  5. HP Envy TouchSmart 4-1215dx Display Replacement: stap 5, afbeelding 1 van 1
    • Peel off the aluminum tape located at the top of the display.
  6. HP Envy TouchSmart 4-1215dx Display Replacement: stap 6, afbeelding 1 van 2 HP Envy TouchSmart 4-1215dx Display Replacement: stap 6, afbeelding 2 van 2
    • Disconnect the ribbon cable and peel off the connected tape from the display.
  7. HP Envy TouchSmart 4-1215dx Display Replacement: stap 7, afbeelding 1 van 2 HP Envy TouchSmart 4-1215dx Display Replacement: stap 7, afbeelding 2 van 2
    • Lift the display up separately from the screen.
    • Peel off the orange tape at the bottom of the display connecting to the laptop.
  8. HP Envy TouchSmart 4-1215dx Display Replacement: stap 8, afbeelding 1 van 1
    • Lift up the display.
    • If your display is cracked or shattered, you should tape up the effected parts in order to avoid injury.
Conclusie
Isaac York
157 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 6
Altijd: 235
