Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
You may need to replace the wireless adapter if your computer can't connect to any wireless network. Be sure that you do not break the antenna connector wires.
Wat je nodig hebt
Remove the single screw holding the accessory plate. This is a PH0 2.0x2.5 screw.
Remove the screw with PH 0 screwdriver that is holding the wireless adapter in. This is PM 2.0x2.5 screws.
4 andere personen hebben deze handleiding voltooid.
Één opmerking
Hi, I use this exact laptop but my wifi card was changed and it didn’t come with Bluetooth so i wanted to know if this
”https://www.aliexpress.com/item/Dual-Ban...
can work for me and if its OK to buy it. Thanks
