Ga door naar hoofdinhoud
HP Envy TouchSmart 15 Wireless Adapter Replacement
Wat je nodig hebt
  1. HP Envy TouchSmart 15 Wireless Adapter Replacement, Battery: stap 1, afbeelding 1 van 1
    • Press the battery release tab and the battery will pop up.
  2. HP Envy TouchSmart 15 Wireless Adapter Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery from the laptop, it will come out easily.
  3. HP Envy TouchSmart 15 Wireless Adapter Replacement, Accessory Plate: stap 3, afbeelding 1 van 2 HP Envy TouchSmart 15 Wireless Adapter Replacement, Accessory Plate: stap 3, afbeelding 2 van 2
    • Remove the single screw holding the accessory plate. This is a PH0 2.0x2.5 screw.
  4. HP Envy TouchSmart 15 Wireless Adapter Replacement: stap 4, afbeelding 1 van 3 HP Envy TouchSmart 15 Wireless Adapter Replacement: stap 4, afbeelding 2 van 3 HP Envy TouchSmart 15 Wireless Adapter Replacement: stap 4, afbeelding 3 van 3
    • Pry the accessory plate up from the back of the laptop by applying force upwards where the screw was removed.
  5. HP Envy TouchSmart 15 Wireless Adapter Replacement, Wireless Adapter: stap 5, afbeelding 1 van 2 HP Envy TouchSmart 15 Wireless Adapter Replacement, Wireless Adapter: stap 5, afbeelding 2 van 2
    • Remove the screw with PH 0 screwdriver that is holding the wireless adapter in. This is PM 2.0x2.5 screws.
  6. HP Envy TouchSmart 15 Wireless Adapter Replacement: stap 6, afbeelding 1 van 3 HP Envy TouchSmart 15 Wireless Adapter Replacement: stap 6, afbeelding 2 van 3 HP Envy TouchSmart 15 Wireless Adapter Replacement: stap 6, afbeelding 3 van 3
    • Hold the wireless adapter and gently remove the white and black wires from it. The connectors will come out straight up.
    Hi
    Today I open my laptop to clean up a bit of dust. and by mistakenly I break black connector. not the thing is that the connector part from wireless card stuck inside black cable. but i can still use wifi without any problem. my question is " Is there any affect on my laptop if i leave it like this ?" and another question what is the functioning of that black cable ?
    hope I will get reply soon.please reply me on ronak.r.30588@gmail.com
    Thank you
    Ronak
    Ronnie M - Antwoord
Conclusie
4 andere personen hebben deze handleiding voltooid.
Robert Patterson
1.442 Reputatie
5 handleidingen geschreven
USF Tampa, Team 2-6, Sullivan Fall 2015 Lid van USF Tampa, Team 2-6, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G6
4 Leden
10 handleidingen geschreven
Één opmerking
Hi, I use this exact laptop but my wifi card was changed and it didn’t come with Bluetooth so i wanted to know if this
https://www.aliexpress.com/item/Dual-Ban...
can work for me and if its OK to buy it. Thanks
temidayoabayomizannu - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 3,099
