Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Press the battery release tab and the battery will pop up.
Remove the battery from the laptop, it will come out easily.
Remove the single screw holding the accessory plate. This is a PH0 2.0x2.5 screw.
Pry the accessory plate up from the back of the laptop by applying force upwards where the screw was removed.
Press the clips on the edges of the RAM modules outward to pop them out.
You can now remove the RAM modules you need to replace. You can replace the top one, the bottom one, or both if needed.
3 andere personen hebben deze handleiding voltooid.
