Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Press the battery release tab and the battery will pop up.
Remove the battery from the laptop, it will come out easily.
Remove the single screw holding the accessory plate. This is a PH0 2.0x2.5 screw.
Pry the accessory plate up from the back of the laptop by applying force upwards where the screw was removed.
Remove the screw from the wireless adapter with a PH0 screwdriver then move the adapter out of the way to access the CMOS battery.
Use a plastic or metal spudger to release the CMOS battery from the clips.
Één andere persoon heeft deze handleiding voltooid.
