Inleiding
To replace your hard drive, first remove the current one from the black rubber sleeves and put the rubber sleeves on your new hard drive. Make sure you have your new drive oriented correctly so you can plug it back in.
Wat je nodig hebt
Remove the two black 6.35mm PH #0 screws with a screwdriver from the top of the hard drive.
Remove the two silver 6.35mm PH#0 screws from the bottom of the hard drive.
Remove four 3.5 mm PH#0 screws on the sides of the hard drive.
6 andere personen hebben deze handleiding voltooid.
