Ga door naar hoofdinhoud
HP Envy M6-1205DX Motherboard Replacement
Wat je nodig hebt
  1. HP Envy M6-1205DX Motherboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Lay the device face down to begin.
  2. HP Envy M6-1205DX Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Slide the release mechanism to the left to release the battery.
  3. HP Envy M6-1205DX Motherboard Replacement: stap 3, afbeelding 1 van 2 HP Envy M6-1205DX Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Remove the battery.
  4. HP Envy M6-1205DX Motherboard Replacement, Touchpad: stap 4, afbeelding 1 van 1
    • Using a Phillips #1, remove the 8 10.6mm screws.
    • Also using a Phillips #1, remove the 8.6mm screw.
  5. HP Envy M6-1205DX Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Slide the center panel down to remove it.
  6. HP Envy M6-1205DX Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Using a Phillips #1, remove the 3.5mm screw.
    • Our computer did not come with a hard drive so you should have one in the empty hole. We have marked where we believe the screws will be in orange.
    • Using a Phillips #1, remove the four 10.6mm screws.
  7. HP Envy M6-1205DX Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Pull the disk drive out to remove it.
  8. HP Envy M6-1205DX Motherboard Replacement: stap 8, afbeelding 1 van 2 HP Envy M6-1205DX Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Using a Phillips #1, remove the two 2.4mm screws.
  9. HP Envy M6-1205DX Motherboard Replacement: stap 9, afbeelding 1 van 2 HP Envy M6-1205DX Motherboard Replacement: stap 9, afbeelding 2 van 2
    • Flip the black tab up on the clamp that holds the ribbon cable in place.
    • Pull the cable back with your fingers or a pair of tweezers.
  10. HP Envy M6-1205DX Motherboard Replacement: stap 10, afbeelding 1 van 2 HP Envy M6-1205DX Motherboard Replacement: stap 10, afbeelding 2 van 2
    • Flip the computer back over
    • Use the plastic opening tool to pry the keyboard up .
  11. HP Envy M6-1205DX Motherboard Replacement: stap 11, afbeelding 1 van 3 HP Envy M6-1205DX Motherboard Replacement: stap 11, afbeelding 2 van 3 HP Envy M6-1205DX Motherboard Replacement: stap 11, afbeelding 3 van 3
    • Carefully lift the keyboard up.
    • Flip up the black tab holding the large ribbon cable down.
    • Push both sides of the small white tab forward to release the small ribbon cable.
    • Pull both the cables out to remove them.
    • Remove the keyboard.
  12. HP Envy M6-1205DX Motherboard Replacement: stap 12, afbeelding 1 van 3 HP Envy M6-1205DX Motherboard Replacement: stap 12, afbeelding 2 van 3 HP Envy M6-1205DX Motherboard Replacement: stap 12, afbeelding 3 van 3
    • Flip the small white tab up to release the ribbon cable.
    • Pull to remove.
    • Repeat the same steps for the other cable.
  13. HP Envy M6-1205DX Motherboard Replacement: stap 13, afbeelding 1 van 1
    • Using a Phillips #1, remove the four 5.6mm silver screws.
  14. HP Envy M6-1205DX Motherboard Replacement: stap 14, afbeelding 1 van 2 HP Envy M6-1205DX Motherboard Replacement: stap 14, afbeelding 2 van 2
    • Use the plastic opening tool to pry the face plate off the rest of the frame.
    • Once you pry all of the snaps up lift the face plate off.
  15. HP Envy M6-1205DX Motherboard Replacement, Fan: stap 15, afbeelding 1 van 1
    • Using a Phillips #1, remove the two 10.6 mm screws.
    • Gently pull back on on the cable to unplug it.
  16. HP Envy M6-1205DX Motherboard Replacement: stap 16, afbeelding 1 van 1
    • Pull the fan out to remove it.
  17. HP Envy M6-1205DX Motherboard Replacement, Motherboard: stap 17, afbeelding 1 van 2 HP Envy M6-1205DX Motherboard Replacement, Motherboard: stap 17, afbeelding 2 van 2
    • Using a Philips #1, remove the five 5.0 mm screws.
    • Gently pull the mini power connectors to remove them.
    • Gently pull the two ribbon cables to remove them.
    • Pull the black tab to remove the LCD screen connector.
  18. HP Envy M6-1205DX Motherboard Replacement: stap 18, afbeelding 1 van 1
    • Gently pull the motherboard away from the case on the lower left-hand corner.
  19. HP Envy M6-1205DX Motherboard Replacement: stap 19, afbeelding 1 van 1
    • Gently pull the case away from the motherboard on the upper right-hand corner.
  20. HP Envy M6-1205DX Motherboard Replacement: stap 20, afbeelding 1 van 1
    • Pull the motherboard out of the laptop, taking care to detach the cable on the underside as you do so.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Ryan Hatton
634 Reputatie
5 handleidingen geschreven
IUPUI, Team S2-G2, Wilson Fall 2019 Lid van IUPUI, Team S2-G2, Wilson Fall 2019
IUPUI-WILSON-F19S2G2
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 921
