Ga door naar hoofdinhoud
HP Envy 700-030qe CPU Fan Replacement
Wat je nodig hebt
  1. HP Envy 700-030qe CPU Fan Replacement, CPU Fan: stap 1, afbeelding 1 van 3 HP Envy 700-030qe CPU Fan Replacement, CPU Fan: stap 1, afbeelding 2 van 3 HP Envy 700-030qe CPU Fan Replacement, CPU Fan: stap 1, afbeelding 3 van 3
    • Make sure that you are wearing your anti-static wristband. This will prevent damaging any internal parts with any built up static electricity.
    • Unscrew the 10.5mm screw on the left of the desktop using your hand.
    • If it is too tight you may use a torx-head screwdriver or a flat-head screwdriver.
  2. HP Envy 700-030qe CPU Fan Replacement: stap 2, afbeelding 1 van 2 HP Envy 700-030qe CPU Fan Replacement: stap 2, afbeelding 2 van 2
    • Next, remove the side panel by sliding it towards the back of the desktop and pulling up, as shown.
  3. HP Envy 700-030qe CPU Fan Replacement: stap 3, afbeelding 1 van 1
    • Remove the four 120mm Phillips #000 head, 5 mm screws holding the fan.
  4. HP Envy 700-030qe CPU Fan Replacement: stap 4, afbeelding 1 van 1
    • Carefully pull up and disconnect the fan's power cable.
  5. HP Envy 700-030qe CPU Fan Replacement: stap 5, afbeelding 1 van 1
    • Remove the fan by pulling up carefully.
Conclusie
Jessica Resta
235 Reputatie
1 Handleiding geschreven
Cal Poly, Team 5-9, Maness Fall 2015 Lid van Cal Poly, Team 5-9, Maness Fall 2015
CPSU-MANESS-F15S5G9
4 Leden
10 handleidingen geschreven
4 opmerkingen
Im looking to replace the fan in mine, what size would I look for, or even what model would be best?
AzyP Zero - Antwoord
Did you ever determine what fan to use ? I need to order one for my system.
Dennis - Antwoord
I bought the Philips #000 Screwdriver from iFixit as listed above. It is not even close to what is needed. That screwdriver is like a jewelers tiny Philips head. It needs a much bigger screwdriver.
Dennis - Antwoord
Fails to mention the most important part of the entire procedure. That would be to remove the old thermal paste from the top of the CPU with 91-99% isopropyl alcohol and re-apply new thermal paste. Short of doing this almost guarantees failure to maintain proper cooling.
Guy Martin - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 35
Altijd: 3,530
