Ga door naar hoofdinhoud
HP Envy 5660 Scanner Piece Replacement
Wat je nodig hebt
  1. HP Envy 5660 Scanner Piece Replacement, Scanner Glass: stap 1, afbeelding 1 van 1
    • Open the cartridge access area.
  2. HP Envy 5660 Scanner Piece Replacement: stap 2, afbeelding 1 van 1
    • Remove the three 11.5 mm screws with a T10 bit.
  3. HP Envy 5660 Scanner Piece Replacement: stap 3, afbeelding 1 van 3 HP Envy 5660 Scanner Piece Replacement: stap 3, afbeelding 2 van 3 HP Envy 5660 Scanner Piece Replacement: stap 3, afbeelding 3 van 3
    • Locate the cover hinge on the right side of the printer.
    • Pull the hinge off of the scanner to allow the scanner to open to 90 degress.
  4. HP Envy 5660 Scanner Piece Replacement: stap 4, afbeelding 1 van 2 HP Envy 5660 Scanner Piece Replacement: stap 4, afbeelding 2 van 2
    • Remove the 12 mm screws on the left side of the printer with a T10 bit.
  5. HP Envy 5660 Scanner Piece Replacement: stap 5, afbeelding 1 van 2 HP Envy 5660 Scanner Piece Replacement: stap 5, afbeelding 2 van 2
    • Remove the 11.5 mm screw with a T10 bit to release the spring-loaded hinge.
    • Since this is a compression spring, the hinge will snap downwards as soon as it is loosened.
  6. HP Envy 5660 Scanner Piece Replacement: stap 6, afbeelding 1 van 3 HP Envy 5660 Scanner Piece Replacement: stap 6, afbeelding 2 van 3 HP Envy 5660 Scanner Piece Replacement: stap 6, afbeelding 3 van 3
    • Pull the plastic side cover off of the printer.
    • You may need to lift the printer and push the cover downwards as it is latched onto the bottom of the printer.
    • Plastic opening tools or a metal spudger may also be used.
  7. HP Envy 5660 Scanner Piece Replacement: stap 7, afbeelding 1 van 1
    • Remove the five 11.5 mm screws located at the bottom of the scanner.
    • Steps 3-6 were intended to create easier access to these screws. However, they will still be difficult to reach.
    • The top of the scanner will now easily pull off.
  8. HP Envy 5660 Scanner Piece Replacement: stap 8, afbeelding 1 van 2 HP Envy 5660 Scanner Piece Replacement: stap 8, afbeelding 2 van 2
    • Pry the old scanning glass up with a metal spudger.
    • There are adhesives under the scanning glass. Be careful not to break the glass while removing it.
  9. HP Envy 5660 Scanner Piece Replacement, Scanner Piece: stap 9, afbeelding 1 van 3 HP Envy 5660 Scanner Piece Replacement, Scanner Piece: stap 9, afbeelding 2 van 3 HP Envy 5660 Scanner Piece Replacement, Scanner Piece: stap 9, afbeelding 3 van 3
    • The scanning piece is located in the bottom half of the scanner that was not separated from the printer.
    • Lift the scanning piece and detach the ribbon cable by gently pulling on it.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Ryan Steakley
781 Reputatie
5 handleidingen geschreven
Cal Poly, Team S1-G6, Livingston Winter 2018 Lid van Cal Poly, Team S1-G6, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G6
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 10
Altijd: 897
