Ga door naar hoofdinhoud
HP Envy 5660 LCD Replacement
Wat je nodig hebt
  1. HP Envy 5660 LCD Replacement, LCD: stap 1, afbeelding 1 van 1
    • Lift the scanner to open up the printer cartridge access area.
  2. HP Envy 5660 LCD Replacement: stap 2, afbeelding 1 van 2 HP Envy 5660 LCD Replacement: stap 2, afbeelding 2 van 2
    • Remove the two 12 mm screws with a T10 bit.
  3. HP Envy 5660 LCD Replacement: stap 3, afbeelding 1 van 3 HP Envy 5660 LCD Replacement: stap 3, afbeelding 2 van 3 HP Envy 5660 LCD Replacement: stap 3, afbeelding 3 van 3
    • Use a metal spudger to pry open the front panel.
    • Work your way all the way around the front panel doing the same.
    • Gently flip the cover over, exposing the motherboard.
    • There will be loud popping sounds when the cover is being separated from the rest of the printer.
  4. HP Envy 5660 LCD Replacement: stap 4, afbeelding 1 van 2 HP Envy 5660 LCD Replacement: stap 4, afbeelding 2 van 2
    • Remove the four 4.5 mm screws from the motherboard with a T6 bit.
    • Gently remove the motherboard from the top of the LCD, but make sure the ribbon cables are still attached.
    • Beware damaging the white ribbon cable.
  5. HP Envy 5660 LCD Replacement: stap 5, afbeelding 1 van 2 HP Envy 5660 LCD Replacement: stap 5, afbeelding 2 van 2
    • Remove the four 5 mm screws with a T6 bit, allowing you to separate the LCD from the cover,
  6. HP Envy 5660 LCD Replacement: stap 6, afbeelding 1 van 1
    • Place the metal spudger underneath the LCD and gently lift up to remove the LCD.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Ryan Steakley
790 Reputatie
5 handleidingen geschreven
Cal Poly, Team S1-G6, Livingston Winter 2018 Lid van Cal Poly, Team S1-G6, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G6
4 Leden
10 handleidingen geschreven
2Gids Commentaar
Great description but there is a part needed - the LCD. Is that part available? How do I get it?
Thanks,
PJE
pateckelberry - Antwoord
Ditto, I'm in the same position, did you ever find the part/LCD replacement screen?
Tessa Robles - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 23
Altijd: 1,486
