Ga door naar hoofdinhoud
HP Envy 4-1105dx Battery Replacement
Wat je nodig hebt
  1. HP Envy 4-1105dx Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Power off the device before beginning disassembly. Disconnect all external devices.
    • Flip the device on its back.
  2. HP Envy 4-1105dx Battery Replacement: stap 2, afbeelding 1 van 1
    • Unscrew and remove the one 7.5 mm Phillips-head screw using Phillips #1 screwdriver.
  3. HP Envy 4-1105dx Battery Replacement: stap 3, afbeelding 1 van 1
    • Unscrew twelve 6.0 mm Phillips-head screws using Phillips #1 screwdriver.
  4. HP Envy 4-1105dx Battery Replacement: stap 4, afbeelding 1 van 1
    • Use the plastic opening tool (which is short and has a thin end for prying open device parts) to pry open the back case of the device.
  5. HP Envy 4-1105dx Battery Replacement: stap 5, afbeelding 1 van 1
    • Once the device is open, move the ribbon cable to the side.
  6. HP Envy 4-1105dx Battery Replacement: stap 6, afbeelding 1 van 1
    • Use the flat end of a plastic spudger to disconnect the battery cable from its socket in the motherboard.
  7. HP Envy 4-1105dx Battery Replacement: stap 7, afbeelding 1 van 1
    • Unscrew and remove the three 4.0 mm Phillips-head screws that hold the battery in place, using a Phillips #1 screwdriver.
  8. HP Envy 4-1105dx Battery Replacement: stap 8, afbeelding 1 van 1
    • Lift the battery up and remove.
    • Removing the battery can dislodge the touchpad bracket. Place the battery carefully over the alignment pins.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Parvathy Nambidi
301 Reputatie
2 handleidingen geschreven
Één opmerking
Worked very well, many thanks
Tony Chan - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 1,205
