Ga door naar hoofdinhoud
HP Envy 23-d060qd TouchSmart Speaker Replacement
Wat je nodig hebt
  1. HP Envy 23-d060qd TouchSmart Speaker Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Use your hands to unclip the plastic snaps on the back panel of the device.
  2. HP Envy 23-d060qd TouchSmart Speaker Replacement: stap 2, afbeelding 1 van 1
    • Remove the three 11.5mm PH2 screws from the back panel.
    • The screws will not fall out of the back panel, but they will unscrew to release the back panel.
  3. HP Envy 23-d060qd TouchSmart Speaker Replacement: stap 3, afbeelding 1 van 1
    • Now, take the back panel off by pulling at it gently with your hands.
  4. HP Envy 23-d060qd TouchSmart Speaker Replacement, Speakers: stap 4, afbeelding 1 van 1
    • Remove the receiver for the keyboard and mouse with your hands.
  5. HP Envy 23-d060qd TouchSmart Speaker Replacement: stap 5, afbeelding 1 van 2 HP Envy 23-d060qd TouchSmart Speaker Replacement: stap 5, afbeelding 2 van 2
    • Remove the four 17.5mm T15 screws from the speakers.
    • Remove the five 7.5mm T15 screws from the cover plate.
    • Remove the cover plate with your hands.
  6. HP Envy 23-d060qd TouchSmart Speaker Replacement: stap 6, afbeelding 1 van 2 HP Envy 23-d060qd TouchSmart Speaker Replacement: stap 6, afbeelding 2 van 2
    • Disconnect the two speaker connections from the motherboard with your hands. Use your hands to gently pull the plastic piece at the ends of the wires.
    • Be gentle when disconnecting any wired connections. Pulling on the wires can damage them.
  7. HP Envy 23-d060qd TouchSmart Speaker Replacement: stap 7, afbeelding 1 van 2 HP Envy 23-d060qd TouchSmart Speaker Replacement: stap 7, afbeelding 2 van 2
    • Remove the speakers from the computer, and if needed, separate by disconnecting the wires between them.
    • Be gentle when separating wired connections. Pulling on the wires can damage them.
Conclusie
Zachary Dicks
1.117 Reputatie
7 handleidingen geschreven
Cal Poly, Team 5-10, Maness Fall 2015 Lid van Cal Poly, Team 5-10, Maness Fall 2015
CPSU-MANESS-F15S5G10
4 Leden
14 handleidingen geschreven
Één opmerking
where to get the replacement speaker???????
Clovis Young - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 1,388
