Ga door naar hoofdinhoud
HP Envy 23-d060qd TouchSmart RAM Replacement
Wat je nodig hebt
  1. HP Envy 23-d060qd TouchSmart RAM Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Use your hands to unclip the plastic snaps on the back panel of the device.
  2. HP Envy 23-d060qd TouchSmart RAM Replacement: stap 2, afbeelding 1 van 1
    • Remove the three 11.5mm PH2 screws from the back panel.
    • The screws will not fall out of the back panel, but they will unscrew to release the back panel.
  3. HP Envy 23-d060qd TouchSmart RAM Replacement: stap 3, afbeelding 1 van 1
    • Now, take the back panel off by pulling at it gently with your hands.
  4. HP Envy 23-d060qd TouchSmart RAM Replacement, RAM: stap 4, afbeelding 1 van 2 HP Envy 23-d060qd TouchSmart RAM Replacement, RAM: stap 4, afbeelding 2 van 2
    • Pop off the easy-access cover to get into the RAM module.
  5. HP Envy 23-d060qd TouchSmart RAM Replacement: stap 5, afbeelding 1 van 2 HP Envy 23-d060qd TouchSmart RAM Replacement: stap 5, afbeelding 2 van 2
    • Push out the four clips that hold the RAM modules to the side.
    • The RAM modules will pop open after you unclick all four clips.
  6. HP Envy 23-d060qd TouchSmart RAM Replacement: stap 6, afbeelding 1 van 1
    • Pull out each module.
    • Replace RAM with desired replacement.
    • When substituting your RAM in, make sure to line up the edges with the lines on the RAM compartment so that the RAM is able to fit inside properly.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Zachary Dicks
1.117 Reputatie
7 handleidingen geschreven
Cal Poly, Team 5-10, Maness Fall 2015 Lid van Cal Poly, Team 5-10, Maness Fall 2015
CPSU-MANESS-F15S5G10
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 29
Altijd: 3,230
