Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Use your hands to unclip the plastic snaps on the back panel of the device.
Remove the three 11.5mm PH2 screws from the back panel.
Now, take the back panel off by pulling at it gently with your hands.
Remove the five 7.5mm T15 screws from the cover plate.
Remove the cover plate.
Use your hands to separate the fan's wired connection to the motherboard. Use your hands to gently pull the plastic piece at the ends of the wires.
3 andere personen hebben deze handleiding voltooid.
