Ga door naar hoofdinhoud
HP Envy 23-d060qd TouchSmart Fan Replacement
Wat je nodig hebt
  1. HP Envy 23-d060qd TouchSmart Fan Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Use your hands to unclip the plastic snaps on the back panel of the device.
  2. HP Envy 23-d060qd TouchSmart Fan Replacement: stap 2, afbeelding 1 van 1
    • Remove the three 11.5mm PH2 screws from the back panel.
    • The screws will not fall out of the back panel, but they will unscrew to release the back panel.
  3. HP Envy 23-d060qd TouchSmart Fan Replacement: stap 3, afbeelding 1 van 1
    • Now, take the back panel off by pulling at it gently with your hands.
  4. HP Envy 23-d060qd TouchSmart Fan Replacement, Fan: stap 4, afbeelding 1 van 2 HP Envy 23-d060qd TouchSmart Fan Replacement, Fan: stap 4, afbeelding 2 van 2
    • Remove the five 7.5mm T15 screws from the cover plate.
    • Remove the cover plate.
  5. HP Envy 23-d060qd TouchSmart Fan Replacement: stap 5, afbeelding 1 van 2 HP Envy 23-d060qd TouchSmart Fan Replacement: stap 5, afbeelding 2 van 2
    • Use your hands to separate the fan's wired connection to the motherboard. Use your hands to gently pull the plastic piece at the ends of the wires.
    • Be gentle when you separate wired connections. Pulling on the wires can damage them.
  6. HP Envy 23-d060qd TouchSmart Fan Replacement: stap 6, afbeelding 1 van 1
    • Remove the three 8mm T15 screws from the fan.
  7. HP Envy 23-d060qd TouchSmart Fan Replacement: stap 7, afbeelding 1 van 1
    • Pull the fan loose from the computer.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Zachary Dicks
1.117 Reputatie
7 handleidingen geschreven
Cal Poly, Team 5-10, Maness Fall 2015 Lid van Cal Poly, Team 5-10, Maness Fall 2015
CPSU-MANESS-F15S5G10
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 19
Altijd: 3,644
