Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Use your hands to unclip the plastic snaps on the back panel of the device.
Remove the three 11.5mm PH2 screws from the back panel.
Now, take the back panel off by pulling at it gently with your hands.
Use your hands to unclip the plastic bezels for the DVD drive and ports.
To unclip the plastic bezels, push the middle of each plastic bezel towards the center of the computer, and then pull them outwards.
Remove the nineteen 10mm T15 black screws from the edge of the computer.
Lift up the computer by the base very slowly, and disconnect the three wired connections to the display with your hands. Always disconnect wired connections from the plastic base.
Set the computer aside, and use a small knife to cut the strips attaching the display to the digitizer.
Use a plastic spudger to unclip the 3 ribbon clips on the back of the display.
Remove the four 7mm T15 silver screws from the edge of the computer.
Gently pull the display free from the digitizer with your hands.
Remove the four 17.5mm T15 screws from the speakers.
When the speakers are free, use your hands to pull them free from the digitizer.
Use your hands to pull the plastic bezel off of the digitizer.
7 andere personen hebben deze handleiding voltooid.
16 opmerkingen
From where can I buy the glass to replace?
i wont 5 pics please send yor number watsap or send me Offer price for HP ENVY 23-d117a glass
Thanks >>
Feras emad
00966543470171
info@fersawy.com
687535-001 this is the part required
Model No HP envy 23 Delhi 0201 N.
Serial no. CZC 31443 LD kindly let me know whether it is available and please mail the details to sunitha.jijo@yahoo.com
Hi.
My touchscreen has been cracked too.
Can anyone help to direct me to somewhere to buy a replacement screen please?
frank_scullion@yahoo.co.uk
Thanks in anticipation
