Ga door naar hoofdinhoud
HP Envy 23-d060qd TouchSmart Display Assembly Replacement
Wat je nodig hebt
  1. HP Envy 23-d060qd TouchSmart Display Assembly Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Use your hands to unclip the plastic snaps on the back panel of the device.
  2. HP Envy 23-d060qd TouchSmart Display Assembly Replacement: stap 2, afbeelding 1 van 1
    • Remove the three 11.5mm PH2 screws from the back panel.
    • The screws will not fall out of the back panel, but they will unscrew to release the back panel.
  3. HP Envy 23-d060qd TouchSmart Display Assembly Replacement: stap 3, afbeelding 1 van 1
    • Now, take the back panel off by pulling at it gently with your hands.
  4. HP Envy 23-d060qd TouchSmart Display Assembly Replacement, Display: stap 4, afbeelding 1 van 2 HP Envy 23-d060qd TouchSmart Display Assembly Replacement, Display: stap 4, afbeelding 2 van 2
    • Use your hands to unclip the plastic bezels for the DVD drive and ports.
    • To unclip the plastic bezels, push the middle of each plastic bezel towards the center of the computer, and then pull them outwards.
    • You may want to lay the computer face down, on a flat, clean surface to ensure nothing falls out when disassembling the computer for next steps.
    One screw to remove the DVD drive is easier and safer than removing the bezel.
    Art Venable - Antwoord
    Hi where can i find the Display?
    Erkan Tekin - Antwoord
  5. HP Envy 23-d060qd TouchSmart Display Assembly Replacement: stap 5, afbeelding 1 van 1
    • Remove the nineteen 10mm T15 black screws from the edge of the computer.
    • Lay the computer on its front when preforming this step, and leave it face down for the rest of the guide.
    Had to remove the base assembly to get at one of the screws holding the display on.
    Had to disconnect speaker wires.
    Also had to disconnect a number of small connections at the top of the device - webcam, microphone, etc.
  6. HP Envy 23-d060qd TouchSmart Display Assembly Replacement: stap 6, afbeelding 1 van 1
    • Lift up the computer by the base very slowly, and disconnect the three wired connections to the display with your hands. Always disconnect wired connections from the plastic base.
  7. HP Envy 23-d060qd TouchSmart Display Assembly Replacement: stap 7, afbeelding 1 van 1
    • Set the computer aside, and use a small knife to cut the strips attaching the display to the digitizer.
  8. HP Envy 23-d060qd TouchSmart Display Assembly Replacement: stap 8, afbeelding 1 van 1
    • Use a plastic spudger to unclip the 3 ribbon clips on the back of the display.
  9. HP Envy 23-d060qd TouchSmart Display Assembly Replacement: stap 9, afbeelding 1 van 1
    • Remove the four 7mm T15 silver screws from the edge of the computer.
  10. HP Envy 23-d060qd TouchSmart Display Assembly Replacement: stap 10, afbeelding 1 van 1
    • Gently pull the display free from the digitizer with your hands.
  11. HP Envy 23-d060qd TouchSmart Display Assembly Replacement: stap 11, afbeelding 1 van 2 HP Envy 23-d060qd TouchSmart Display Assembly Replacement: stap 11, afbeelding 2 van 2
    • Remove the four 17.5mm T15 screws from the speakers.
    • When the speakers are free, use your hands to pull them free from the digitizer.
  12. HP Envy 23-d060qd TouchSmart Display Assembly Replacement: stap 12, afbeelding 1 van 1
    • Remove the three 10mm T15 screws from bezel.
  13. HP Envy 23-d060qd TouchSmart Display Assembly Replacement: stap 13, afbeelding 1 van 1
    • Use your hands to pull the plastic bezel off of the digitizer.
    If digitizer glass is shattered can this be reassembled without glass or touch screen function?
    Steve Cacace - Antwoord
Conclusie
7 andere personen hebben deze handleiding voltooid.
Zachary Dicks
1.117 Reputatie
7 handleidingen geschreven
Cal Poly, Team 5-10, Maness Fall 2015 Lid van Cal Poly, Team 5-10, Maness Fall 2015
CPSU-MANESS-F15S5G10
4 Leden
14 handleidingen geschreven
16 opmerkingen
On step 5 you've to remove also the 4 silver screw that keep display to the mainboard chassis.
illola - Antwoord
From where can I buy the glass to replace?
Aram Vardanyan - Antwoord
i wont 5 pics please send yor number watsap or send me Offer price for HP ENVY 23-d117a glass
Thanks >>
Feras emad
00966543470171
info@fersawy.com
Feras Emad - Antwoord
687535-001 this is the part required
Model No HP envy 23 Delhi 0201 N.
Serial no. CZC 31443 LD kindly let me know whether it is available and please mail the details to sunitha.jijo@yahoo.com
Sunitha.jijo@yahoo.com - Antwoord
Hi.
My touchscreen has been cracked too.
Can anyone help to direct me to somewhere to buy a replacement screen please?
frank_scullion@yahoo.co.uk
Thanks in anticipation
Frank Scullion - Antwoord
I need replacement digitizer. pls contact if you have any thx. mavioglu@hotmail.com
oguz - Antwoord
Hi,
My touchscreen has been broken and i need a new one for replacement or if some technical support do it.
hp envy recline 23-k220ne
My email is:
alberto@surweb.es
thanks ;)
Alberto - Antwoord
Hi, I also need a new screen for my hp envy 23 , links would be greatly appreciated
glg2401@gmail.com
George - Antwoord
i need a 23 inch hp touchsmart screen very badly anyone???
jayfinks - Antwoord
Hi, I am in need of the replacement glass for my HP ENVY 23 touchscreen also. It fell and cracked while in transportation. The computer is still operational but my glass screen is cracked in a about 8 places. Where can I find the glass cover for this touchscreen at a reasonable price? Reach me at : ( markmccord71801@att.net ). Thanks for the assistance.
Mark McCord - December 5th, 2018
markmccord71801 - Antwoord
Depends on what you think is reasonable. There are several on eBay, but there are variations in the ribbon cable configurations within the same series, which means you probably will have to disassemble to see which one you need.
Amy Stinson -
Im also looking for a screen for my HP Envy Touchsmart 23se-d494 anyone know where to buy one??
Derek Vasquez - Antwoord
glass replacement the computer still works?
Need to replace a glass for HP Envy 23-d160qd.
Availability ? Cost ?
Scott 'Dragon' Runde - Antwoord
Hola , do you know number part ?
Araceli Sánchez Bautista - Antwoord
Hi.
Can anyone help to direct me to somewhere to buy a replacement screen please? agencethaly@gmail.com
Nathalie Legault - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 61
Altijd: 13,960
