Inleiding
The RAM of the computer allows the computer to manage resources better. This guide will help you replace or upgrade it. You will need a replacement RAM card to complete this guide and replace the current card. You will need is the iFixit Opening Tool, a 00 Phillips-head Screwdriver, and a T5 Torx-Head Screwdriver.
Wat je nodig hebt
Unscrew all visible screws.
Use the T5 Torx Screwdriver and remove the four visible 6.5mm screws on the bottom of the laptop.
One 2.5mm screw, is located where the disk reader was once located. Use a Phillips #00 screwdriver to remove the single screw that connects the bottom cover of the laptop to the bottom frame.
Één andere persoon heeft deze handleiding voltooid.
