Inleiding
If the battery in your laptop is not operating correctly by either not receiving or retaining a charge or if it is overheating, you might need to replace the battery. Follow this guide to replace the battery by taking off the back cover off the laptop, disconnecting the inoperative/damaged battery, and finally connecting the new battery to the laptop. In order to complete this replacement, you will need the iFixit Opening Tool, a 00 phillips-head Screwdriver, and a T5 Torx-Head Screwdriver.
Wat je nodig hebt
Unscrew all visible screws.
Use the T5 Torx Screwdriver and remove the four visible 6.5mm screws on the bottom of the laptop.
One 2.5mm screw, is located where the disk reader was once located. Use a Phillips #00 screwdriver to remove the single screw that connects the bottom cover of the laptop to the bottom frame.
3 andere personen hebben deze handleiding voltooid.
Één opmerking
These instructions were also applicable to an HP 17ar050 Pavillion Laptop.
