Ga door naar hoofdinhoud
HP Envy 17-J013CL Memory Module Replacement
Wat je nodig hebt
  1. HP Envy 17-J013CL Memory Module Replacement, Battery: stap 1, afbeelding 1 van 1
    • Lay the laptop with the battery facing towards you.
    • Remember to disconnect the AC cable and other power sources from the device before replacing/repairing parts.
  2. HP Envy 17-J013CL Memory Module Replacement: stap 2, afbeelding 1 van 1
    • Grab hold of the small battery slider and apply pressure to the right.
    • The laptop itself will push the battery out for you once the switch slides all the way to the right.
  3. HP Envy 17-J013CL Memory Module Replacement: stap 3, afbeelding 1 van 3 HP Envy 17-J013CL Memory Module Replacement: stap 3, afbeelding 2 van 3 HP Envy 17-J013CL Memory Module Replacement: stap 3, afbeelding 3 van 3
    • Pull the battery out and let go of the battery slider.
  4. HP Envy 17-J013CL Memory Module Replacement, Back Panel: stap 4, afbeelding 1 van 2 HP Envy 17-J013CL Memory Module Replacement, Back Panel: stap 4, afbeelding 2 van 2
    • Use a PH1-screwdriver to loosen the 7mm screw. The screw will not fully come out as it is held by a washer underneath but will come out enough to open it.
  5. HP Envy 17-J013CL Memory Module Replacement: stap 5, afbeelding 1 van 1
    • Gently pull the back panel off starting from the battery side towards the back.
    • Pull it back as it snaps out of the holding sockets.
    • It is preferred to use both hands when pulling the back panel off to prevent bending it out of shape.
  6. HP Envy 17-J013CL Memory Module Replacement, Memory Module: stap 6, afbeelding 1 van 2 HP Envy 17-J013CL Memory Module Replacement, Memory Module: stap 6, afbeelding 2 van 2
    • Locate the memory stick inside.
  7. HP Envy 17-J013CL Memory Module Replacement: stap 7, afbeelding 1 van 2 HP Envy 17-J013CL Memory Module Replacement: stap 7, afbeelding 2 van 2
    • On both sides of the module, place a thumb on each of the metallic holding pins.
    • Gently pull on the pins to release the spring holding in the module.
  8. HP Envy 17-J013CL Memory Module Replacement: stap 8, afbeelding 1 van 2 HP Envy 17-J013CL Memory Module Replacement: stap 8, afbeelding 2 van 2
    • Gently slide the module out of the memory slot.
    • Pay in mind of the module's orientation as it will only go in one way with a little gap in the module to identify orientation.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Matt McBride
899 Reputatie
6 handleidingen geschreven
USF Tampa, Team 16-6, Blackwell Spring 2017 Lid van USF Tampa, Team 16-6, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G6
3 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 11
Altijd: 806
