Ga door naar hoofdinhoud
HP Envy 17-J013CL Battery Replacement
Wat je nodig hebt
  1. HP Envy 17-J013CL Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Lay the laptop with the battery facing towards you.
    • Remember to disconnect the AC cable and other power sources from the device before replacing/repairing parts.
  2. HP Envy 17-J013CL Battery Replacement: stap 2, afbeelding 1 van 1
    • Grab hold of the small battery slider and apply pressure to the right.
    • The laptop itself will push the battery out for you once the switch slides all the way to the right.
  3. HP Envy 17-J013CL Battery Replacement: stap 3, afbeelding 1 van 3 HP Envy 17-J013CL Battery Replacement: stap 3, afbeelding 2 van 3 HP Envy 17-J013CL Battery Replacement: stap 3, afbeelding 3 van 3
    • Pull the battery out and let go of the battery slider.
Conclusie
To reassemble your device, line up the battery and place it down into the metallic prongs for a stable connection.
Matt McBride
845 Reputatie
6 handleidingen geschreven
USF Tampa, Team 16-6, Blackwell Spring 2017 Lid van USF Tampa, Team 16-6, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G6
3 Leden
Één opmerking
where does one buy a replacement battery for this HP envy17?
brandondelcastillo - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 14
Altijd: 1,963
