Ga door naar hoofdinhoud
HP Envy 17-3070NR Optical Drive Replacement
Wat je nodig hebt
  1. HP Envy 17-3070NR Optical Drive Replacement, Back Cover: stap 1, afbeelding 1 van 2 HP Envy 17-3070NR Optical Drive Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Before you begin taking apart the computer, make sure that it is completely powered off.
    • Slide the release latch away from the nearest edge.
    • Slide the back cover off of the computer.
  2. HP Envy 17-3070NR Optical Drive Replacement: stap 2, afbeelding 1 van 3 HP Envy 17-3070NR Optical Drive Replacement: stap 2, afbeelding 2 van 3 HP Envy 17-3070NR Optical Drive Replacement: stap 2, afbeelding 3 van 3
    • Remove the six 3.7mm Phillips screws.
    • Slide the back cover until it clicks, then lift it straight off.
  3. HP Envy 17-3070NR Optical Drive Replacement, Optical Drive: stap 3, afbeelding 1 van 3 HP Envy 17-3070NR Optical Drive Replacement, Optical Drive: stap 3, afbeelding 2 van 3 HP Envy 17-3070NR Optical Drive Replacement, Optical Drive: stap 3, afbeelding 3 van 3
    • Remove the four 3.7mm Phillips screws that secure the optical drive to the computer.
    • Slowly lift the optical drive away from the computer ensuring that you don't put stress on the connecting cable.
    • Do not fully lift off the optical drive as there is still a cable that connects it to the motherboard.
    • Remove Sub Speaker assembly first in order to remove Optical drive. Carefully disconnect speaker connector.
  4. HP Envy 17-3070NR Optical Drive Replacement: stap 5, afbeelding 1 van 3 HP Envy 17-3070NR Optical Drive Replacement: stap 5, afbeelding 2 van 3 HP Envy 17-3070NR Optical Drive Replacement: stap 5, afbeelding 3 van 3
    • Carefully disconnect the connecting cable by lifting the white clamp with a Flathead screwdriver and pulling on the blue tab away from connector.
Conclusie
Jon Fuson
140 Reputatie
1 Handleiding geschreven
Cal Poly, Team 14-8, Amido Spring 2015 Lid van Cal Poly, Team 14-8, Amido Spring 2015
CPSU-AMIDO-S15S14G8
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 1,244
